Arion/Fergunson/Termal - auto update question
Information exchange on receiver software, including updates, problems and fine tuning.
Old 18-01-2006   #1
Teiga's Avatar
My System: metronic ouralis 3
Hi
I have a ouralis evo3 witch is a arion based decoder.
My prob is that I can’t seem to change the setting in software update submenu on my receiver!
Every time I try to change from the default setting "F/W" to some other like for example "DATA" I get a error message and default setting prevails.
My point on doing this is that I think it would turn firmware's auto roll off.
I think that would prevent the fake key attacks that my satellite provider sends to my receiver, causing it to keep loosing/changing the keys I have put on it.
I have partial solution for the prob, but I still have to wait +- 20 secs every time I suffer one of those attacks... it gets annoying when they make it every 15 minutes!!
Teiga is offline   Reply With Quote
Old 18-01-2006   #2
rockchang's Avatar
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded
Talking
Originally Posted by Teiga
Hi
hi, Teiga, good questions , and the following is my opinion.
1. software upgrade menu is the function for receiver to receiver sw/data transfer, it has nothing to do with the emu or autoroll
2. if u use the software EMU function, as i know, arion based receiver doesnt support the function of turning the AUTOROLL off.
they only provide a menu to turn the EMU ON/OFF.
if u use a cam, such as MRV, then u can turn the autoroll off in the cam menu.
3.try to solve ur problem by upgrading the latest software.
good luck!
rockchang is offline   Reply With Quote
Old 18-01-2006   #3
georgekamal's Avatar
good luck!
hai, dear rock, have any software for autoroll the dr**m? the software
is given by u is geting keys but lost two digits are only in "zeero and zeero"
.,any solution for world in box?
regards-george
georgekamal is offline   Reply With Quote
Old 18-01-2006   #4
Teiga's Avatar
ok... thanks for the explanation rockchang
bye
Old 19-01-2006   #5
rockchang's Avatar
Cool
regards-george
hi,georgekamal
there isnt any autoroll sw for wib that can autoroll dream tv now. u need to enter keys manually to watch it.
here in china, the most popular way to get dream tv is using X430 + 8515 FUN CARD. it is very easy to find the autoroll card file.
(and it was said from yesterday a porn channel is availble after 22:00 at night )
good luck!
Old 19-01-2006   #6
hi,georgekamal
good luck!
thank u rock ,but can i use the x-sat410 (conaxempedded) receiver? b coz
i have only this model in x-sat)
regards-george
Old 19-01-2006   #7
Teiga's Avatar
going back to ouralis3 (fergunson/arioner/termal....)
does anyone know a firm, based in 6684 and suporting D+, that doesnt have autoroll?
auto, question, update
[IMG] code is Off
Similar Threads
How Can I Update My Reciver excell Viaccess 12 19-07-2008 07:20 AM
Free-xtv Update Sky Box Not Responding ars1604 Receiver software, international Section 17 07-01-2005 09:19 AM
Transponder update 30/06/03 Satdude Transponders & channels 1 06-05-2004 01:36 PM
Update Windows today - before it gets Blasted net1 Computer Discussion 13 22-08-2003 12:19 AM
does viaccess update over the air?? giver Viaccess 0 07-07-2003 07:33 PM
