technomate tm-1500 ci+super. problemInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 08-12-2005 Location: hastings , uk
My System: Technomate 1500ci + super , motorised 90cm triax , sky freesat uk |
Hi there Well i dont know what's wrong with it , but after i watch it a couple of hours it doesn't respond to any comands anymore and i have to reset it from the front buttons Power+Up for 5 seconds . Only the on off command responds . Can anyone tell me what's going on please ? Model= tm-1500ci+super sw version = 1.53 ( jan 10 1006 ) hw version = 1.11 boot version = 2.10 (08:10 ) ch version = dec 05 ThanksI hope this is the right place to put this thread , i can't find anywhere for receiver problems. | ||
| Regular Member Join Date: 31-10-2004
| Sounds like you are trying to view a m****vision channel, if this is the case then I have the same problems, this was happening before the last patch update so it looks like we need another software update. | ||
Yes , i tried to watch m vision but then i did do a factory reset and reloaded a earlyer soft version and it does the same . I'm wandering if it's anything to do with my setup as i have it looped through 2 other receivers , echostar dsb2200 and hyundai hss-1120 , but again i tried without loop and it does the same . It also could be a heat problem . I dont know what to do anymore. Thanks | ||
| Member Join Date: 14-01-2006 Location: london
My System: technomate |
Hi, there I've got same problem , my receiver technomate 1500 ci+ super update by him self , new wrong key every day even i change them with a new key, still same ....................I think we have to change a new software ... | ||
| | #5 | ||
I think i've sorted mine , it was the scart lead ( i hope ) , changed everything on it until i got to the last option , the scart lead , it's been working ok all day now , no problems whatsoever . Who has similar problems , try to change your connections , u never know . I'll let u know if any changes . Thanks for your support . | ||
| | #6 | ||
| Regular Member Join Date: 22-12-2005 Location: Yorkshire
My System: Technomate 1500ci+ super (upstairs), Phoenix Apollo MC (downstairs) both running off a cheapo 80cm dish with a twin output monoblock 13° & 19.2°. Sky+ (downstairs) piped 'round the house. | Yeah, had probs with scart in top hole , remote not workin, sluggish... read elsewhere was a problem!!!! | ||
| | #7 | |||
| Super Nutty Mod Join Date: 03-10-2003 Location: Essex
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka ! |
| | #8 | ||
Hi sorry for the late reply , just changed it with a similar one , nothing fancy . It's still ok just =i tried to set up a motor with it , a technomate stab 120 usals i think , put a scaffold pole vertical and then the dish and the motor toghether on it . Now , i got a strong signal on thor 1* west and when i tried to move the motor with the move west command from the receiver it moved in very short litlle steps backward and forwards like a yoyo . A few times it moved like i wanted it to but most of the time it didn't . Is this normal or am i doing something wrong ? I must mention that the receiver has the 21-01-2006 patch and the temperature outside was 0 degrees | ||
| | #10 | ||
| problem, super, technomate, tm1500 |
Similar Threads | ||||
| Technomate 5500ci super diseqc problem | cableman | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 2 | 26-10-2005 02:18 PM |
| Technomate 1500 CI+ - does it REALLY work with cards without a CAM? | Beebman | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 18 | 28-09-2005 12:53 PM |
| Have a problem with Vision Plus | mgharbawy | Satellite PC Card Receivers & Internet by Satellite | 1 | 15-02-2004 10:47 PM |
| TECHNOMATE TM-5500CI on Astra 28.8E? | jAk | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 27-01-2004 04:42 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
