Formating A Technomate
Information exchange on receiver software, including updates, problems and fine tuning.
Old 21-01-2006   #1
stevienire's Avatar
My System: Technomate 1000D + Moteck SG2100a + 85CM Dish
Is there anyway to completely wipe a Technomate 1000D. I've done factory reset,and NVRAM clear but to no avail. Theres a couple of faults with mine and I think If I completely wipe it and reinstall frimware etc it would cure the problem.
Problems are: On the channel selection screen it shows lines going down the screen, I've used both scart and and the RF connector.
it also wont lock onto feeds when I know it should. I mean when on a transponder with a feed on it if you move fine east or west up pops quality to 70%+ then if I go to save if disapears back down in the red and below 30%. I've also plugged in a TM 1500 which has no problems with the feeds.
When moving fine east or west using diseqc on a horizontal channel both signal and quality dissapear, all is fine on a vertical channel
__________________
stevienire is offline   Reply With Quote
Old 22-01-2006   #2
BGonaSTICK's Avatar
I don't know of an erase image for the Techno's. You could try al-sats.
TBH it sounds more like a hardware problem. If it were me, I'd stick an original image back on it and RMA it sharpish.
STICK
formating, technomate
[IMG] code is Off
Similar Threads
Technomate v manhatten telly2 Digital systems 5 03-04-2006 10:40 PM
Technomate 5500 dapci Moschino DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 25-11-2004 09:50 PM
Technomate 5500 steviewilson DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 28-02-2004 10:40 AM
TECHNOMATE TM-5500CI on Astra 28.8E? jAk DISH SETUP: Single sat, Multi-Sat & Motorised systems 1 27-01-2004 04:42 PM
Icecrypt and TechnoMate wilson3010 Cams and decoders General 0 24-09-2003 06:43 AM
