Software Upgrade Problem: Fortec Star Lifetime
Information exchange on receiver software, including updates, problems and fine tuning.
Old 21-02-2006   #1
My System: Fortec Star Lifetime PAS7/10, 68.5E Intelsat 604 LNB: C & KU Bands
Hello,
I have a Fortec Star Lifetime with Al7bar(T) 2.64 software boot version
6.0 on it. Yesterday I tried to upgrade it using the software from the fortec star
site. After everything else had been done, following instructions and with
download complete on my PC, I pressed OK. However on the receiver, it
showed as if it was still processing. I waited another 10 minutes but
nothing changed. Then I switched off the receiver and then turned it on.
It switched on and appeared to be processing and then hang up. Switching
on and off again results in the same thing. Then I tried to reload the
software but this failed, saying update failed.
So where did I go wrong? Is there anything else that can be done? Have I just kissed my fortec star lifetime goodbye?
Thanks.
FTA-Digger
FTA-Digger is offline   Reply With Quote
Old 22-02-2006   #2
hi friend
hi
plz download new software and stb loader use new ok
1-u connect pc and reciver
2-power is on ur reciver
3-open stb loader and open in file
4-click on download ok all is ok
i send u new software and his loader plz download it thanks
http://rapidshare.de/files/13873508/updater.zip.html
rizwan
rizwan2005 is offline   Reply With Quote
Old 23-02-2006   #3
Wink
rizwan,
Many thanks. I will try and give you feedback accordingly.
FTA-Digger
Old 24-02-2006   #4
This is what happening after your suggestions It managed to download the file to the receiver i.e. the Flash File. After 100% (before download complete) in the background I was able to read "Flash Burning...". But then if I try to turn the reciver off and on again, it runs as if it is processing and then hangs again as before. So am still stuck....
Old 24-02-2006   #5
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Could try Jtagging, some advice can be found on US al7bar forums for your receiver.
For example, _www.bartv.ca or _www.al7barfiles.tk
Llew is offline   Reply With Quote
Old 25-02-2006   #6
HI
OK DOTWORY PLZ CHECK AGIAN WITH ANY OLD FIRLE PLZ AND TELL IF U HAVE ANY OLD FILE IS OK NOT PLZ TELL ME I SEND U OLD FIEL INSHALLAH ALL IS OK
RIZWAN
fortec, lifetime, problem, software, star, upgrade
[IMG] code is Off
Similar Threads
How to upgrade software Naveedjan2001 Viaccess 0 03-02-2005 04:39 AM
Questions for Fortec Star Lifetime Ultra panathinaikara Cams and decoders General 1 26-08-2004 11:57 AM
EPG Software & Sky's New Cards denis1501 Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 9 22-10-2003 03:52 PM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
Aston to Diseq poitioner problem BazelAd DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 20-08-2003 07:21 PM
