abs-8776 reciever
Information exchange on receiver software, including updates, problems and fine tuning.
Old 10-03-2006   #1
My System: humax,pi300
abs-8776 reciever
does anybody know of anything that can be done with thw abs-8776 reciever it seem to be locked to austar. anything to unlock it and view other channels.
many thanks
secure is offline   Reply With Quote
Old 10-03-2006   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum secure
have a look here and see if you can identifiy a similar looking model, that may then help you to track down some software
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 24-03-2006   #3
thanks i will have a look
Old 17-12-2006   #4
My System: turnkey 700mhz athelon .5gb ram,120 gb,drive j-test j-tag setup
I just started testing oe of these[mine has all chinese lang in menu]
seems to be similar to a 2 tsop 301 with a 5500 decoder
has a 8952 cotroler so should be piece of cake
let u know what i come up with
boxut
boxnut is offline   Reply With Quote
Old 18-12-2006   #5
don't know where my prev reply went but??
Ok this might help get you started..the 8776 is jtagable,via 'cn16'. pinout is " 1,3,5,7,9,11 are ground,
pin 2 is trst,pin 6 is tdo, pin 8 is tdi, pin 10 is tck, and pin 12 is tms. the boot select is a headder just behind
the screw at the center of the board . jumping an inner pin to the pin closest to r106 will boot from the dcu.
the pin at the other end of the headder is 'esel'. there is a master reset 'button' located rear of the system
cpu (sw6).
this ird is a 2 tsop unit so i'm guessing that it is similar to a 301-13. if you are using jkeys you may have to use the
version for the 301 .
in either case, you would have to edit 'jkeys.def ' file to specify 39vf160 (check this) flash chips,and 24c64 eeprom.
I havn't tried new bins yet so don't know what works. this ird may be more like a 2700,4900,drd420
my unit is cofigured for 'jedi'tvb ( asian) but does have some 'fta' features. don't know if the aussi system
has any fta features.
i will see if i can add some pix to help(abs8776.zip)
hope this is useful to you (or anyone) boxnut
Old 29-04-2008   #6
My System: dm7000 amd64
hello
is there any uses for these box's now ?
humax2001 is offline   Reply With Quote
Old 14-06-2008   #7
My System: nothing special
Does anyone have any info on the recovery menu password for this decoder?
mikehunt2008 is offline   Reply With Quote
Old 11-05-2009   #8
My System: Dreambox DM7020
Hi, saw this somewhere...
abs-8776 secret menu
turn the box off at the power point & back on.
when the green lettering " DIGITAL SATELLITE RECEIVER LOADER v3"
appears immediately press down,up the timing on this is important it only works when nothing but
" DIGITAL SATELLITE RECEIVER LOADER v3" is displayed.
The word "UP" will appear in blue lettering at bottom left hand corner if you did it correctly
now press OK,then UP,UP,DOWN.
This will take you to the RECOVERY MENU.
Hillsbysa is offline   Reply With Quote
abs8776, reciever
[IMG] code is Off
Similar Threads
Need Upgrade "Pace DVR 500 digital integrated reciever decoder" logger17 Receiver software, international Section 3 01-04-2005 07:01 PM
reciever thechnostar 9900 P remoram25 Receiver software, international Section 0 07-03-2004 04:27 AM
Help, fun card not working in strongsat reciever jacklee66 Cams and decoders General 5 11-02-2004 04:19 PM
Reciever compatability johnd231159 Magic Module 0 29-08-2003 11:36 PM
Reciever For Cyprus. koolclub Digital systems 0 11-07-2003 05:31 PM
