help with technosat t-888Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 02-03-2006 Location: UAE
My System: Technosat T-888 | Hey everyone. I have a tehnosat T-888 PLUS. I dowloaded a software into my receiver but the channels are still scrambled. I heard that there is an activation code that I have to enter into my receiver. Is that correct? If yes, can anyone help me get it? by the way, what does the master code do to the receiver, i mean what can we use it for? appreciate your help. | ||
| Member Join Date: 01-12-2004
| Dear mam empire here`s your help 1-reboot your stb 2-press exit then 6108(fastly) your stb will reboot after that code 3-go to menu prantel lock there is a new step will be apper (chennel lock) change it to temmpory. 4-press blue key to save. 5-reboot your stb again and press exit 8088. and have a nice time. good luck my friend. what loader and software do you use for technosat t-888 and where can i found it as i have looked everywhere and can not find it. If you have the loader and software cand you forwarded to my e-mail email address removed please. many thanks | ||
| Last edited by Topper; 18-03-2006 at 03:36 PM. Reason: email address removed | |||
| | #5 | ||
My System: Technosat T-888 | Thanks for the help guys. the thing is i tried to use the "exit + 6108" method but it didnt work, it just takes me to another channel no matter how fast i try. It only worked in the first time i got the receiver but not anymore. About the software and the loader, they all come in the same zip file at this URL: http://www.dsrsoftware.com/. All what you need to do is to follow the instructions in the word file. Does anyone know any other way to unlock the scrambled channels? I feel that it has something to do with the master code, doesn't it? | ||
| t888, technosat |
Similar Threads | ||||
| Technosat IR-7000 Upgrade | akshariff | Receiver software, international Section | 16 | 18-04-2006 01:34 PM |
| technosat 6000plus | star777 | Receiver software, international Section | 58 | 20-11-2005 08:57 PM |
| Technosat Ir 7000 | mnadeem | Receiver software, international Section | 50 | 02-09-2005 09:59 PM |
| Technosat 9300 ap | wael77 | Receiver software, international Section | 2 | 14-08-2004 01:57 PM |
| xtreme or technosat 5500CI ? | dcjag | Digital systems | 2 | 23-09-2003 02:33 PM |
