Need info for Factory Reset
Information exchange on receiver software, including updates, problems and fine tuning.
Old 17-03-2006   #1
My System: Strong SRT 4400
Red face Need info for Factory Reset
Need to make a factory reset for my Strong SRT4400 but cannot manage to find this funtion. Can anybody guide me how to do it as I forgot PIN and everything I try, I keeps requesting the PIN.
Thanks.
charcamil is offline   Reply With Quote
Old 17-03-2006   #2
Jeff_19341
Posts: n/a
Some receiver default PIN's are 0000, try that.
Jeff
Old 18-03-2006   #3
Thanks Jeff, but already tried that. Usually, Strong uses the 1111 as factory PIN. On manual it says that if you forget PIN make a factory reset (obviosly you loose everthing) but it don`t mention how to do it.
Bye and thanks the same.
Old 18-03-2006   #4
Jeff_19341
Posts: n/a
Hi
Have you had a look at http://www.strong-technologies.com/frmDownloads.aspx
Downloads of user manuals.,
If your exact model is not there, the proceedure is often the same on a similar box.
Cheers
Jeff
Old 19-03-2006   #5
Jeff_19341
Posts: n/a
Hi
Have you tried this?
Click on menu on the remote.
Use up/down keys until you highlight "Installation" click on enter.
Use up/down keys to highlight "Factory Set" click on enter.
Then follow the on screen instructions from there.
Old 20-03-2006   #6
Thanks Jeff for your help. Till now when I click enter on "Installation" it requests the PIN. I will keep on trying and keep you informed if I manage to.
Bye
Old 20-03-2006   #7
Jeff_19341
Posts: n/a
Very frustrating for you, have you tried an email to Strong outlining your problem? They might have a solution, as I am sure that you are not the only one who has forgotten their PIN.
I know that it does not help, but I have never changed the factory set PIN on any of my receivers. Too many numbers to try and remember nowadays. Best wishes with your continued search for a solution.
Old 22-03-2006   #8
Thumbs down No luck
Thanks Jeff for your help. Unfortunatly I have to quit and drop the reciever to my agent maybe he can do something. Tried everything and from Strong support, all I got were PIN numbers which did not work either. Anyway maybe if someday I manage to unlock it, I will give the instructions on this forum.
Bye Charles.
factory, info, reset
[IMG] code is Off
Similar Threads
Live feeds today 05.12.07 Satdude Transponders & channels 619 05-12-2007 11:11 PM
Live feeds May Satdude Transponders & channels 32 04-06-2005 08:40 PM
Live feeds today 31.07.04 Satdude Transponders & channels 0 01-08-2004 12:31 AM
Live feeds today 30.04.04 Satdude Transponders & channels 16 30-04-2004 10:40 PM
