explain by pictures of J-tag the receiver flash(flash dump)for all 20 point jtag padInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 14-12-2005 Location: SYRIA
My System: STARCOM X550D SUPER HW:9.6 LOADER:2.0 | soon i 'll put the complete explanations sorry i'm so busy but quickly critical notes: 1. the distance between resisters and jtag pad should no more than 10 cm or will not work 2. the distance between resisters and lpt can be as u want 3.u can connect the resisters to jtag pad direictly 4.some receivers have 20 pin on board not only jtag pad so at this case u need 20 pin connector lick in 7 picture | ||
My System: STARCOM X550D SUPER HW:9.6 LOADER:2.0 | ________________________________________ _____________________________________________ | ||
| | #5 | ||
My System: STARCOM X550D SUPER HW:9.6 LOADER:2.0 | and here the used program: JTAG_UP_15_07_2005 the link _http://www.dijitalboard.com/depo/index.php?action=downloadfile&filename=JTAG_UP_15_ 07_2005.ZIP&directory=J%20Tag%20Programlar%FD& ________________________________________ choose your lpt port then flash size then start then: U should first erase current damaged flash then load new one after finished u should click stor befor un plug electricity if u have healthy flash u can make backup by choose read ______________________________ i'm searching for link for flash dump file: and here some: 1. _http://www.digital-sistem.com/depo/index.php?direction=0&order=&directory=Flash%20Dum p%20Files&PHPSESSID=a616e8f5f6bd7d64927e8e0b3aaa70 02 2. _http://www.deposat.com/depo/forumdisplay.php?fid=18 3. _http://www.dijitalboard.com/depo/index.php?PHPSESSID=f699b622e74e37d9f14bba2ed088e1 45&direction=0&order=&directory=2-Flashdump%20Dosyalar%FD 4. _http://www.mavitunasat.net/index.php?PHPSESSID=b3a0d706ffa244c892d894c1835129 95&direction=0&order=&directory=FLASH_DUMP_FILES 5. _ ______________________________ here can find starsat 550 650 3100 2100 3500 super flash dump file: _http://www.deposat.com/depo/showthread.php?tid=114 | ||
| | #6 | |||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." |
They are now. All attachments have to go through the moderation queue first. ![]() L. | |||
| | #7 | ||
| Portuguese Mod Join Date: 26-08-2005 Location: Portugal
My System: Portable 30cm dish, used to work on Hispa, Astra & Hotbird, with Teka and Datacom! Centrino 1,7 GHtz with Vista emulator for XP SP2! Experience with Drake & HeaD, both sucessfuly! Won't respond to PM's!! All the help in the main forum! | | ||
| | #9 | |||
| Member Join Date: 02-10-2005 Location: FR
My System: Starsat SR-X 650CI ultra |
can you say me if this diagram works fine for starsat receiver (650ci)? Thx SuRgEoN | |||
| | #10 | |||
can you say me if this diagram works fine for starsat receiver (650ci)? If yes, where can i find them (for ULTRA and not SUPER) Thx a lot Surgeon | |||
| dumpfor, explain, flashflash, jtag, pad, pictures, point, receiver |
Similar Threads | ||||
| Samsung dead. PLZ HELP!!! | Zebo | Receiver software, international Section | 9 | 16-02-2006 12:05 AM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
| Freeview receiver spec will omit 7-day EPG | net1 | Terrestrial Television, Digital and Analogue | 0 | 27-06-2003 08:56 PM |
