problem with silvercrest sl65 lidl special
Information exchange on receiver software, including updates, problems and fine tuning.
Old 04-04-2006   #1
lula member
tapfit2004's Avatar
My System: humax 5400 fortecstar sl65 quali tv ir 4 digiboxes dragon cam funcard7 sm3d12 motor wavefrontier t90 90cm dish 1m dish
i am having a problem loading a channel list into the sl65. i have patched the receiver using a null modem cable and the bmisoft patch and the 'ewinloader 1.1.6' loader program and the receiver boots and seems to work ok apart from the fact that there is no list of satellites or tp's. i have tried to use 'STBeditor 2.0.23' to load the 'biespiellliste' channel list into the receiver but the progress bar goes to about 10% and stops. i have left this for about 20 minutes with no change. the program does not hang or crash but it loads nothing either. i have also tride to enter satellites manually but this does not work. i thought i might need a jtag connection rather than a null modem but the STBeditor program is for a null modem cable. any help would be appreciated. i have looked around this site and the net for a while but can find no answer. i have also adjusted the com port settings on my computer and this makes no difference either. thanks.
Gigfy
tapfit2004 is offline   Reply With Quote
Old 04-04-2006   #2
My System: pheonix
hi , i am new to this, so sorry if somone has already answered this but could someone please tell what is 'Patched'?
astrahotbird is offline   Reply With Quote
Old 04-04-2006   #3
Amo Amas Amant Admin
Topper's Avatar
Well
I like many others do not wish to waste our time reinventing the wheel please use the search function to ascertain the answer to your question it has been answered many times before
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 10-04-2006   #4
My System: SilverCrest SL65 COMAG Porty II
Hi Tapfit,
I think my post might help you: just 2 days ago I followed the next process and got my box up & running: (INCLUDING the list of SATs and TPs, this is what you need, right?).
I however am not able still to properly insert the K**ys to have "more" channels... This is what I posted a while ago. Pls if you find also some info, share it with me!
How to fuse loader
1) To replace the existing loader 3pE (H/W version 20p9) with new loader A0p1 via RS232.
Please do the below steps to replace loader version 3pE to loader version A0p1.
a) Invoke the loader 3pE(which is already present in box) in DFU mode using front panel keys (CH up + CH dn).
b) Use Winuploader4.2.8 tool and download MINILOADER_3PE_A0P1.urt via RS232.
c) This will update loader version 3pE to loader version A0p1.
d) After downloading the MINILOADER_3PE_A0P1, reboot the box. Now box boot with new loader version A0p1.
How to fuse application
1) Open the eWinloader1.1.6 tool in the PC and download the following urt to update BMI UCS S/W
a) Download the BMISOFT_FTA_KEY_V1P6_08092005.URT to update the key information.
b) Download the BMISOFT_FTA_PATCH_19092005.URT to update the patch information.
c) Download the BMISOFT_FTA_APPL_V1P6_08092005.URT to update the BMISoft application.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Good luck!
silvercrestsl65_user is offline   Reply With Quote
lidl, problem, silvercrest, sl65, special
[IMG] code is Off
Similar Threads
Lidl SilverCrest SL65 or Helios FTA? testpie Digital systems 2 26-10-2006 02:13 PM
Have a problem MPEG2 DVD conversion mgharbawy Computer Discussion 4 21-06-2004 10:02 PM
Have a problem with Vision Plus mgharbawy Satellite PC Card Receivers & Internet by Satellite 1 15-02-2004 10:47 PM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
Aston to Diseq poitioner problem BazelAd DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 20-08-2003 07:21 PM
