Truman tm150 firmware... need ur help badly! :(Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 24-10-2005 Location: Egypt
My System: truman tm150 piii 550 |
I have a truman tm150 receiver, i have the cable, i downloaded the new firmware.. but all i need is the exact steps to upgrade the device.. need to know when to plug the power into the receiver, when to unplug, what to upload first, how to save the channel list.... i searched alot in this forum and others, but found no instructions for my model, seems it's not well known if anyone can help , please go on | ||
| Member Join Date: 03-07-2005 Location: United Arab Emirates - Dubai & Oman
My System: A powerful computer using a TWINHAN card! | You might wanna take a look at the RS-232 wiring too, due to some reasons the manufacturer has re-wired the port. I came across this when I was trying to do the same with my Truman 7000, I will check and let you know how the wiring was done, but, cannot guarantee that the wiring will be the same. Cheers! | ||
| Member Join Date: 23-03-2006 Location: Qatar
My System: Truman Ultra 150 & Starsat X550D Ultra on Hotbird | Hi, I've made an upgrade on my TM150 ultra without any problem with the steps here below: 1 Open the loader and the last version software 2 Switch the receiver off 3 Launch the download with the loader 4 Switch on the receiver (normally the process will start) Regards, | ||
thank you blackhawk for advice, many thanks titmf, it worked as you said i have only one problem, when i tried to take an image of my current channels using the channel editor program - i downloaded my software from www.tmsatsw.com - it failed and i had to research for the channels and arrange them again after update i tried to take an image of the new channel list it worked , but when i open the file with the channel editor, it displays strange characters, and the channels aren't shown does anyone have any idea about that?? thanks; | ||
| | #5 | ||
My System: Truman Ultra 150 & Starsat X550D Ultra on Hotbird | Hi, To be honnest, I've no idea for your Image problem. Maybe someone else. The image is maybe not compatible between 2 different software version ? Regards, | ||
| badly, firmware, tm150, truman |
Similar Threads | ||||
| NOW you can turn your receive super to ultra enter here | jack0 | Receiver software, international Section | 364 | 17-11-2008 12:26 PM |
| Humax BTCI-5900 firmware | DaNileKnight | Receiver software, international Section | 6 | 02-02-2008 04:01 PM |
| Viaccess Red Cam V484 firmware. | ANTMAL | Viaccess | 3 | 11-04-2004 12:56 PM |
| I need TF3000CIPPRO firmware October 2003 | ikuwara2000 | Receiver software, international Section | 1 | 04-03-2004 09:03 AM |
| firmware for my elvis programmer | tipsygent | Cards & Programmers General | 3 | 24-01-2004 08:23 PM |
