Technosat Ir 7000Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 02-01-2004
| Found out from technosat that you use a straight thru serial cable to update the firmware, eg pin1 to pin1, pin2 to pin2 etc.. firmware from here http://www.technosat-uae.com/downloads.html | ||
| | #5 | ||
| Regular Member Join Date: 31-08-2003
| Hi I have load the new software from technosat homepage for my reciever .It is called T1740-35.sdl . done good job only have new satelite names , if any one can fined the file name Yin86.sdl it will make the receiver in all cam , i hope becouse till yet no luck | ||
| | #6 | ||
Hi one weak ago i have tried to update the receiver , with the file t1740-35.sdl done good job , but nowing that ist has only many setallit name add it and nothing , try to backup with original soft has serial error . have to press many times menu . but nothing come. what can i do, the original software file is techno20.sdl, or yin86.sdl can any one tell | ||
| | #7 | ||
| HI Can any one tell me how can i open hidden function from remote controll of Technosat ir 7000, or password witch can help , becousae receiver normaly on air updaten , but this function is un awayble . Also waiting that some one can tell me how can i update in all com , multicam , eurocam , if any news very greatfull thanks in regards | ||
| | #11 | ||
| HI i need patch for that receiver , to make this embedded Irdeto II in allcam . the new software does nothing for that , how can we see viacces or seca channel on it , other hand huma5400 irci do that all the function , why not this receiver , please send us the software if any one has , the receiver has also many name like Sat Radar IR401 , or dBy FTA2210 I , and so onfound many links if this help others http://www.cashlesscanada.com/SatRadarIR401.asp http://www.siamdst.com/dby.htm http://www.globalsources.com/gsol/I...d_id/219813?a=b http://www.yinhe.com/en/gddvbt.asp http://www.technosat-uae.com/profile.html please help me to make this receiver best of it | ||
| | #14 | ||
| mnadeem can you explain what can do that HI if this links can help you then most wellcome but also looking others then shortly i will put here http://www.adduniverse.com/technolog...at_ir_7000.asp any way if you put 0000 then it will help and open your setup section , try it or load new software from above links from technosat witch i have given , the software is T1740-35.sdl it will make your set in original position . thanks in regards | ||
| | #16 | ||
| | #18 | ||
| Regular Member Join Date: 22-05-2003 Location: Burgenland, Austria
| I am in Austria, desperately trying to find a replacement remote control for this receiver. I can't operate the box witout a remote - who in Europe would sell such a replacement remote? Any help appreciated! Thanks! | ||
| | #21 | |||
| | #22 | ||
| HI i have found this page , if it will help you , then mostwellcome http://www.nsremote.com/satellite_eng.html | ||
| | #23 | ||
| HI I have some info for that receiver if it is help for hacker to find update or links to make it supper sat , if so embedded Irdeto II decoder CA status softcell version 2.09h IRD status Ird :32.3.32 ca module : softcell v2.09h firm ware : 1.0 loader 3.2 - 1 : 0. 16 ok l -16 ird sw : v3.40 dvc -s driver sw : v2.02 can any one help , i would like to convert in multicam or euro cam | ||
| | #24 | ||
| Hi I have some problem yet my funcard is not functioning in receiver , but original ARY is ok , why is the version is changed or my card is dead , can i also use titenium card , if any one know some thing please post here thanks Also i need diagram or circuit for that receiver where to get , give links also with what software can we open all hidden function of that receiver | ||
| 7000, technosat |
Similar Threads | ||||
| Technosat IR-7000 Upgrade | akshariff | Receiver software, international Section | 16 | 18-04-2006 01:34 PM |
| technosat 6000plus | star777 | Receiver software, international Section | 58 | 20-11-2005 08:57 PM |
| technosat ir 7000 | miox_24 | Receiver software, international Section | 0 | 23-09-2005 03:01 PM |
| Technosat IR 7000 | mnadeem | Receiver software, international Section | 0 | 11-12-2004 11:29 PM |
| Technosat 9300 ap | wael77 | Receiver software, international Section | 2 | 14-08-2004 01:57 PM |
