Kaon HW versionsInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 14-06-2006 Location: Czech Republic
My System: Kaon KSF 570 HW 16.00.A5 | Lo,I have Kaon HW 16.00.A5 with SW 03.00.00 and I can't find any firmaware that matches the HW model. As far as I understood the HW must match. Is that true or can I use different HW model? Any reference to Kaon firmware upgrade manual / faq / etc will be appreciated! Thanks! | ||
| Regular Member Join Date: 18-10-2005 Location: BE
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception from HB Astra 1 and 2 + TopField TF 7700 HDPVR + TwinHan VisionDTV | It is true that the HW version must match exactly (the last digit is an exception, but just match it exactly). The HW version encodes the actual HW in the box and the FW is specific for your HW version. Here you can find FW for your box: http://www.satellitefr.com/Firmwares.html And here you'll find more information: http://satellitefr.bb-fr.com/index.forum?c=1 Most of what I've come across is not in English, but still enough to find ones way around. | ||
My System: Kaon KSF 570 HW 16.00.A5 | Thanks. I've upgraded with 16.00.A1 version (mine was 16.00.A5), the upgrade completed well but now it doesn't find any satellite... :-( The menus are all working. Anything I can do? | ||
| kaon, versions |
