Truman 7000Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 22-06-2006 Location: Egypt
My System: Truman 7000 |
Hi all , i wish anyone can help me out here , i have a Truman7000 box , strange enough it came with factory default software truman vega !! anyhow all was fine i access the code page by going menu/language/english and pressing 9999 ...i upgraded to the latest software for truman 7000 on the site www.tmsatsw.com but after the upgrade i cant access the code page anymore i get nothing , nothing happens at all when i press 9999 ..i install the truman vega software but also nothing happened , any idea what is going on i am goin ..any help is really appreciated | ||
My System: Truman 7000 | okay well first the default sowftware was truman vega !! which doesnt have a cam , so by default when i inserted any card it wasnt readable so i had to update ..anyhow i solved my problem , after u update yr software u simply go to menu/language press red button and then type 2528 ..once u do that two lines will appear which basicly enable emulation mode , by default they are off , turn them on and once again press the red button to save the settings .... some channels will open like the swiss channels ..if not go again to menu / language and press 9999 the code page will open , u can edit they keys there ... | ||
| | #5 | ||
| Member Join Date: 02-06-2007 Location: Cyprus
Hello, Really great post - Very good work!! Finally, people who know about this (rather good generally) receiver. I have a little problem with my Truman 7000: I am trying to apply the daily update .bin files for codes, but it's a rather hit and miss affair. Never seems to work twice in a row in the same way. I guess one should apply a sequence of a) Turning the receiver on and off (from the wall), b) installing the bin file (size 64k), c) applying pre-stored keys. d) Turning the receiver on and off and finally e) Keeping fingers crossed really tight. All these seemed to work (sometimes!) during May. They do not work anymore in June. Has something changed? If not, does anybody have a better sequence for applying those ***.bin files to Truman 7000 receiver? Tnx Qwen | ||
| 7000, truman |
