Arion Receiver software | |
Blog Entries: 5 My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Spectrum analyser. | Did a quick search, but all I could find were resellers for the receiver in North America. It appears to be a relatively bew model, so software may not be available, may be worth E-mailing one of the resellers. | ||
| | #4 | |||
| Member Join Date: 14-04-2004
Thanks | |||
| | #5 | |||
| Specialist Contributor Join Date: 01-09-2004 Location: china
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded |
can u use arion af-1700e to deal with some encrypted channels? | |||
| | #6 | ||
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded | several days ago, i used arion af1700e software to update my startrack world in box receiver, but failed. i think the different boot version cause this failure. | ||
| | #7 | ||
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded | | ||
| | #9 | ||
| Member Join Date: 03-10-2004
| | #10 | ||
| | #13 | ||
| Member Join Date: 12-09-2004
| try this link... hope it will be helpfull http://67.43.4.158/showthread.php?t=59 and http://users.pandora.be/Powersky/ | ||
| | #14 | |||
| Member Join Date: 03-03-2004
Pls help me.. How can I upgrade the software for my receiver..? My receiver is STARTRACK world in box.. Pls get me master code of the receiver.. Rgrds, Pirayas pirayas4*hotmail.com | |||
| | #15 | ||
| Regular Member Join Date: 20-09-2004
| To upgrade your startrack get software from their website starsw.com. The file you download should have an explanation. Also use the SEARCH button at the top of this page and type in startrack...you'll be surprised how much info there is on this receiver | ||
| | #17 | ||
| Definitive Guides Creator Join Date: 03-09-2004 Location: Somerset, UK
My System: Arion AF-8100CI, 80cm Dish | | ||
MSN: wilf*the-webring.co.ukARION AF-8100CI / 80CM EUTELSAT DISH WITH 1 LNB / A PASSION FOR SATELLITES | |||
| | #18 | ||
| Member Join Date: 23-12-2004
| Hi Can somebody help me to find correct satellite receiver? I am searching something similar to polish Ferguson AF-3018SE (it is FTA Arion S170EC type). Tell me please where, in which shop can I find (I am from Belfast) this receiver? If is exist some board especially for Arion-type DVB Sat receivers, then please send me a address… Thank you | ||
| | #20 | ||
| Member Join Date: 28-12-2004
I look to update my Arion AF-1000SE some firmware: http://dvb-upload.com/index.php?dir=...ARION-FERGUSON code & link: www.arion.co.kr Arion AF-1000SE= Ferguson AF-1018SE!!!!! All the software are the same. Ferguson-Made in Poland, Arion-Made in Korea. THX the polish team! The koreans are very closed! They sell the softwares!!! SO, when u look for Arion ,look for the ferguson egal! It's better!!!! arion 1700e=telstar 4018se=openbox 1700e http://www.telstar.com.pl/telstar/index.php index AF 1018SE http://dvb-upload.com/index.php?search=1018&date=0 The list of codes to activate hidden functions in Arion based receivers. For f/w with EMU function to activate it: 1. Go to menu. By pressing menu on your remote 2. Key in : 19370 3. Key in pin: 2486 Now in menu – games, you shall see emu-keys section, should you wish to alter the keys manually, you need to enter pin 0000. If you forgot the pin you had entered, press 0786 to reset it and enter menu or blocked channels. Other Codes to be entered when tuner is in stand by mode. 42114802500 – Full information about your tuner (h/w & f/w) 24680 – Uploading keys (irk) or channels list to the receiver. 74621 – Downloading channels list from the receiver. 74623 – Downloading full set of keys from the receiver. 74620 – Downloading f/w from the receiver (AUC_HEDIT). 14802 – Downloading boot from the receiver (AUC_HEDIT) 14809 – Downloading full f/w with boot from the receiver (AUC_HEDIT) – you get “universal” f/w this way. Test codes: 42125 42126 42127 __________________________________________________ To connect your PC to the receiver, you'll need null modem RS 232 9-pin cable: 1+6---->4 2------>3 3------>2 4---->1+6 5------>5 7------>8 8------>7 __________________________________________________ How to receive the STB Data from the STB to PC. NOTE: Receive indicates that transfers the existing data (STB Data) from the STB to your PC; whereas, Send indicates that transfers the added or modified data from PC to the STB). 1. Choose the "Receive" menu from Main Menu or Toolbar. 2. Turn on the main power of STB. 3. Press special key-code "74621" in the STB stanby mode. 4. The STB Data will be transferred automatically, with a window indicating the process status. (If you wish to abort receiving process click 'CANCEL' button.) 5. When finished the receiving process, click the 'OK' button and then an active window will appear your received data. Please save the data with specific name using "Save As" menu. How to send the STB Data from PC to STB. 1. Choose the "Send" menu from Main Menu or Toolbar. 2. Turn on(reboot) the main power of STB. 3. The STB Data will be transferred automatically, with a window indicating the process status. If you wish to abort sending process click 'CANCEL' button. AF1018SE, AF2018SE, AF3018SE, AF4018SE AF5018CI s/w upgrade Upgrade procedure 1. Power off receiver. 2. Connect PC and receiver using a serial cable. Receiver should be power-off state. 3. Execute "ARIONER.EXE" First, Select proper PORT. ex) COM1 or COM2 4. Click the "Open" button and select "ADA2030SE.auc". Click the "Send program to IRD" button. Then, typically "Last status" shows message of "Waiting connect request ack". Now PC are ready to transfer. 5. Power on receiver upgrade process will be automatically done in a few seconds. You can see the progress with PC and/or receiver. NOTE When receiver shows "Saving" message, you have to be very careful. Never power off during this save time. It couldn't reboot and you have to send back the receiver to us. At the end of the process, small message window at PC will appear. Please don't care about the message. Click "OK" button to clear the message. Receiver reboot automatically. Check front display of receiver. If it shows "----" or any channel number "xxxx", then successful | ||
| | #21 | ||
| Regular Member Join Date: 19-12-2004
| For Arion 1900ci or Powersky1900ci go to this web site :http://satbox.spectranet.tv/ There is a new software dated 21/12/04 . | ||
| | #23 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Software sites & master code lists can be found right here in the receiver software forum h**p://www.satellites.co.uk/php-bin/forum/forumdisplay.php?f=16 | ||
| | #25 | ||
| Member Join Date: 05-02-2005
1. Power off receiver. 2. Connect PC and receiver using a serial cable. Receiver should be power-off state. 3. Execute "ARIONER.EXE" First, Select proper PORT. ex) COM1 or COM2 4. Click the "Open" button and select "ADA2030SE.auc". question where did u get "ADA2030SE.auc". please leme know. | ||
| arion, receiver, software |
Similar Threads | ||||
| Software upgrade for Neosat 9600 SX | Nasir Malik | Receiver software, international Section | 17 | 16-03-2009 08:28 AM |
| Help about Software for receiver | richiesgr | Receiver software, international Section | 1 | 27-03-2008 08:22 AM |
| How can i backup my receiver firmware or software to PC | wongul | Receiver software, international Section | 6 | 11-02-2007 02:45 PM |
| LG receiver software | naloxan | Receiver software, international Section | 5 | 28-05-2005 06:47 AM |
| Freeview receiver spec will omit 7-day EPG | net1 | Terrestrial Television, Digital and Analogue | 0 | 27-06-2003 08:56 PM |
