Fortec Star lifetime diamond ultra DVB-S & TInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 26-08-2006 Location: UK
My System: dbox2, fortec |
hi, Just been given a brand new unit, but haven't got a clue what to do with it! Try to find a little info it has a embedded DVB-S & DVB-T but no card slots, did a google but can't find any info on this unit! The question I'm asking is can this be patched & how anyone got a tutorial & patches & tools etc... Any help will much be Appreciated | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | It will do FreeView DTT (if your local transmitter is carrying it) and satellite. FortecStar have pretty good hobby support, although dunno about this model Try here: _http://www.al7bar-soft1.com/ | ||
| | #3 | |||
My System: dbox2, fortec | Not must luck on this site can't find the boot.file! _http://www.al7bar-soft1.com/FTA/LIFE%20TIME%20DIAMOND%20Ultra/LIFE%20TIME%20DIAMOND%20Ultra%20MAIN.htm#Softwares So if anyone out there as this please contact! The search continues! | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Some boots on this site for Diamonds - _www.geocities.com/nhfs49/FortecstarBoots.htm Llew | ||
| | #5 | ||
My System: dbox2, fortec | Thanks for replay... Can i use Lifetime Diamond boot file on a Lifetime Diamond Ultra? are they the same chip set! If i flash it with this will it work or screw the unit up! | ||
| | #6 | ||
| Member Join Date: 27-04-2005 Location: Merseyside
My System: Technomate 1500CI super, 78cm solid dish, 0.2db LNB, HP Pentium4 PC with XP Home. Foretec Star Lifetime Diamond (more trouble than it's worth) | Try Yahoo Groups and join Fortec users you may get some advise there. I patched ny receiver using ALbar7 software which did work, but have had no end of problems and use the Lifetime Diamond only for DVB-T (freeview) and it's not much good for that! Tell me if you have any success | ||
| diamond, dvbs, fortec, lifetime, star, ultra |
