help me please srx200ci and cw
Information exchange on receiver software, including updates, problems and fine tuning.
Old 24-12-2006   #1
I have emtech receiver em200 ci i download the last version of softwaew 12.86 and when i download the softcam file all codes are going in except cryptworks.i try to checl the file by oping it and i fould that codes (w)are in
so can any one tell me why cryptworks codes did not install into the receiver
d2003 is offline   Reply With Quote
Old 24-12-2006   #2
DeepDiver's Avatar
My System: Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
You probably have a 1M version of this receiver. In this case, there is not enough memory to hold all the data.
What is the HW version ?
DeepDiver is offline   Reply With Quote
Old 24-12-2006   #3
my hardware version is 200
my h/w version is 2.00
model id E224
s/w version 12.86
i want to tell you that i used several softcam file it's size 31k,42k,52k,12k
but he take all the code excpt the w(cryptworks)
Old 24-12-2006   #4
DeepDiver's Avatar
Bear in mind that the STB memory is used for both softcam file and EMU file.
Anyway, this should be a 2M model.
What makes you say that these keys are not in the receiver ? Did you check it at receiver end ? There are good chances that the keys are there, and the related channels do not open simply because the keys expired.
Have a look on the receiver side.
Hope it helps.
Old 25-12-2006   #5
i check the receiver but no way
i check the receiver (code page) and i found that all codes allready there
excecpt cryptworks
i try to remove some codes like viacess and seca to make size less
and download the file again to the receiver but no way
i check also the cryptworks codes (W) and i note that there are two type of
codes one that is short and the other is long but in both cases no way
why why why why why why whywhywhywhywhywhywhywhywhywhywhywhy
i want to open hustler tv please
Old 25-12-2006   #6
DeepDiver's Avatar
I am afraid it is not as easy as just entering keys.... else the Pay TV business would collapse... especially xxx
E.G.There are other packages using DCW keys such Sex View or MCT.Keys for these packages become clear on a very few occasions, and never last long. usually a couple of hours.
With regards to Hustler TV, I suppose you refer to Hustler TV Europe. Its programmes in UK go through SKY UK, on Astra 2A at 28.2 .
These TV channels are encrypted using the NDS system which is unviolated.
So if you want to see this package, you need to buy a genuine subscription.
Hope it helps.
Old 25-12-2006   #7
i do it befor
you know that from 10 day's ago i download softcam file and it open it free
but where i download new software version for my receiver the cryptworks codes are goen!!! so i try to know why but no way and no way to go back for old version because you can't download old ver. 12.85in new ver.12.86
so all iam asking now is any way to open it again.such entering this keys by
remote control (notes:the codes are so long and code page just take 16 codes only)
Old 27-12-2006   #8
So No Way
So Finally No Way For Ope This Channals Again
Thanks For Helping
Old 29-12-2006   #9
tamazgha2003's Avatar
My System: dreambox 500s
for cryptoworks you have to use dreamloader v.2.04
http://dindaadel.free.fr/Condor/dreamloaderV204_.rar
and a good softcam.key,like this one:
Technomate/Kaon Sunny/Opos/SKY X/S2 DVB/Neta SoftCam by Keymaker --
;Enigma/DVB/Condor Emtech/Next 2005,Astra,Clark-Tech,Vantage
tamazgha2003 is offline   Reply With Quote
srx200ci
[IMG] code is Off
