How can I earse receiver flash memoryInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 04-03-2004
| I have SR-X1500D super . I wrongly downloaded software for model SR-1500D_SUPER_MK_II Would any one tell me how can I earse flash memory on receiver to enable clean downloading ? Please help Ibrahim Samir ibrahim_samahy@hotmail.com | ||
| Member Join Date: 23-03-2004
Hi,, To reset Flash memory of Nokia you can use dboxhack software using DBM http://homepages.enterprise.net/smalone/images/bdm.gif Below the modem on the main board near the back panel and left of the SAT Scart you'll find the 10-pin connector (XP01) which will be used to read out and program the flash memory. http://homepages.enterprise.net/smal...ages/xp01s.jpg To make development for the 68340 easier, Motorola implemented a so-called background debug mode (BDM). With the XP01 connector and a simple interface, you can connect an ordinary PC to the 68340 for debug purposes. We can use this debug mode of the processor to read out and re-program the flash memory. The XP01 connector is where the BDM interface is connected to. The pins are numbered alternately (left, right, left, right). To be sure the pin layout is correct, you should measure where the two GND pins are. The pins of the XP01 connector are connected directly to the 68340 processor. Any wrong connections to XP01 will probably result in damage to the processor. http://homepages.enterprise.net/smalone/images/bd32.jpg Bootblock (BOOT.BIN) - This is a separate part of the software which initializes all components of the receiver with their default values and loads the software into the receiver's RAM. The boot loader also tests its own function, during this test you can see messages like SWCHECK or SELFTEST in your display. The size of the bootblock file is 128k. Settings (SETTINGS.BIN) - This is the part of the software that contains your particular settings, including the channel list and other selected items. There are programs on the files page that allow you to edit this file and change channel names etc. The size of the settings file is 48k. Firmware (FIRMWARE.BIN) - This is the Firmware for the receiver as used for serial download. It does not contain the bootblock. The size of the firmware file is 896k Custom ( EEPROM0.BIN / EEPROM1.BIN) - These are effectively images of your flashram. EEPROM0.BIN will include the bootloader. These files are used by the (DOS) program dboxhack.exe. The size of each file is 512k. http://homepages.enterprise.net/smal...s/dboxplan.zip For more information : http://homepages.enterprise.net/smalone/dbhack01.html Regards,, astofail | ||
| Member Join Date: 30-12-2004
Hi, I have your same proplem please help me to solve my proplem if you can. Thanks.Mehran please send your research to my email: Mehran_nice9*yahoo.com | ||
| earse, flash, memory, receiver |
Similar Threads | ||||
| IRD120 mesmo com JTAG morreu (cont.) | ilmc2001@SAPO.PT | FTE | 2 | 06-05-2006 04:22 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| wiped the int eeprom and flash memory | doggy | Cards & Programmers General | 8 | 01-01-2004 07:47 PM |
| New antypiracy STMicroelectronics chip | net1 | Daily Satellite and Broadcast industry News | 0 | 22-11-2003 10:21 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
