Need Help Relook 400Support forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers. | |
| Member Join Date: 07-11-2006 Location: TASMANIA
My System: EMTECH 320 pvr amd | ![]() I have a huge problem that i don't know where to start. I was installing "HL216_400_pal_usb_all_noboot" and my laptop locked up half way through installing it. Now all I get on the screen when I turn on the relook is 'BOOTING' and that is where is stops. I can access the relook through USB or Ethernet, have not tried serial yet. Is there a way of restoring original image to at least get it working again. . I hope someone has some advice as I hope it is not buggered. Cheers njbnellie ![]() | ||
My System: EMTECH 320 pvr amd | Hi, thanks for that, as I'm relatively new to all this, it is probably a stupid question, what is a (JTAG) is it a piece of software and where do i find info on using it, I dont know anyone here in Tassie that can help me. thanks in advance Njbnellie | ||
| Member Join Date: 17-08-2003
simple explanation would be you have to reload the boot menu into the chip a jtag is a lead that you connect to pc & to the board in the relook you then run the correct sw thats about it after that you are back to normal if you can contact me via pm i can give you more info. | ||
| | #6 | ||
| ive uoloaded the files and info to _ttp://www.mediafire.com/?9u3tyyn3unm download & unzip to a folder and have a good read instructions are included you can ims me if you add me to msn messenger | ||
| | #7 | ||
| Member Join Date: 02-06-2007 Location: Aartselaar, Belgium
My System: Relook 400s - kathrein UFS 810 - multytenne 45 twin | You can find your answer here... http://www.denktenk.com/modules/doku...k_jtag_service | ||
| | #9 | |||
| Member Join Date: 12-12-2004
As you can still connect to the receiver using a usb cable hopefully the above will work for you. Mac. | |||
| | #10 | ||
My System: EMTECH 320 pvr amd | Thanks for that macarmagh, it worked. I managed to reflash highland onto the relook and it starts, I just have to figure oout what other software i need on the relook as i cant seem to get any sat feeds now. cheers njbnellie ![]() | ||
| | #12 | ||
| Member Join Date: 30-06-2008 Location: UKRAINE
My System: RELOOK 400S/PACE HD/FERGUSON8900/PIONEER 1530/ | I have still problem with my relook 400s. I connect jtag and write new boot is ok only still no connect my pc and relook. I push power when start relook and nothing ![]() My pc no see relook !! Any sugestion what is wrong ? Why still no connect usb/serial port with my pc ? I change difrent cable usb, change pc ( 2 laptops and 1 normal pc) and still no connect only on LCD USB UPGRADE. Normal switch is still BOOTING. I write all boot and this same problem co connect? I want write by jtag image and i dont khnow why this do it ? thx a lots | ||
| 400, relook |
