Relook 400s Box Halted
Support forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers.
Old 15-10-2008   #1
My System: 2.40m Solid Paraclipse Hydro Humax 5400Z G-Guard 9600 Dragon cam 3 Jonsa 1.80m
Does anyone know how to resolve box halted message on relook 400s, abcom image, thank u. please be specific as unit starts then box halted message comes up. thanks
powel000 is offline   Reply With Quote
Old 16-10-2008   #2
tomthebomb1968's Avatar
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Hi there. Are you using the abcom enigma image ar a dgs based image? Definately souunds like a bootloader problem. Have you recently changed from an enigma based image to a dgs based image. If so you must flash the box with an "all" image and not a "noboot" image as these images contain no bootloaders. So you may have an enigma image with a dgs bootloader or vice versa. Do you have the required software and the correct usb lead to reflash.
You will need a program called flashtools and the usb vesta driver.
tomthebomb1968 is offline   Reply With Quote
Old 16-10-2008   #3
Thanks for ur kind help. I have no clue if the image is enigma based or dgs. What I did is I pressed reboot enigma and the box freaked out in stead of retart box. Thanks
Old 23-12-2008   #4
My System: Echostar ad3000ip,Topfield 5200,Relook 400s,Sinuta 120cm,Triax 88cm and other 2 dishes,Sharp,Inverto,Alps LNBs,Belden sat cable and many more
@powel000,
I hope this will help you.I can share my knowledge If You need some more
Regards,
kamaxx is offline   Reply With Quote
Old 24-12-2008   #5
mazen_094's Avatar
@ powel000,
I use Mutant 200 and recently flashed an AB Enigma image, and experienced the very same problem. Another con for this image that its database supports 4 satellites only. That was more than enough to intimidate me.
I flashed my receiver with SifTeam-1.9.3C and very happy with its stability. Still configuring the image to meet my requirements.
If you don't have a good reason to use AB Enigma I recommend SifTeam image.
mazen_094 is offline   Reply With Quote
Old 25-12-2008   #6
Sifteam image differs abcom enigma image as the followings
Sifteam image
+Fast zapping
+Easy to use
+Stability
-Skins
Abcom Image
+IPK Files
+Skins
-No holding on remember the last channel.I think This is general problem because of eprom.
400S has a flash memory capacity of 8mb but I met box halted when I totally downloaded image,skins,addons and etc. bigger than 8mb
Old 25-12-2008   #7
mazen_094's Avatar
@Kamaxx
You are right mate the channel zapping is TERRIBLY fast!!! Very good point for SifTeam. I should say that my system has gone read-only, and so I have to reflash it to solve the problem. I think my system has gone read-only because I didn't changed the mID value at the first bootup. At that time I got no clue what that mID things is.
@ Powel0000
Ok mate! You suffer most among us all. Have you chosen another image or what?
Old 26-12-2008   #8
The AbCom enigma image for the 400s is rock solid, I have been using it 24/7 for months, as a server to peers and my Dreambox 800 & 500, I have tried others but always end up going back as reliability is required, I know this image will run perfect and i can leave the house safe that my box wont lock up and leave my friends missing the match, *****
Old 26-12-2008   #9
mazen_094's Avatar
@tomthebomb1968
I ve got no clue how an 400s image will perform on a 400s box. But the general rule is to keep playing with the box to minimum and add required plugins ONLY. As a beginner I will expect a lot of hangings, haltings, read-only systems. I am still a beginner as far as linux-based STBs are concerned. After having flashed about 5 images, I am, honestly, proud that I have never had to JTAG my box YET !!!
Old 26-12-2008   #10
mazen_094's Avatar
@kamaxx
Hi m8,
I have flashed my receiver with SifTeam 1.9.3C and this is the second time my systems goes read-only. Although I changed the model ID to 20 right at the first boot, it went read only after less than 24hours.
What am I doing wrong
Old 28-12-2008   #11
Try changing the mid to 40 or Dreamox 7000
Old 29-12-2008   #12
mazen_094's Avatar
Ok man,
I did try this but no luck. I also tried many other images than SifTeam and still have the same problem.
On a brighter note, NOT all folders are read only. I also found from other forums that the majority of Enigma based images have the same restriction when you try to modify the contents of specific folders such as the /share folder. In other words, the creators of Enigma based images deliberately compile those images and add the read only restriction to some sensitive folders such as the /share folder.
I will be grateful if you can post a link to an Enigma based image for relook 200s and doesn't have this silly limitation.
As a Linux fan, I will also try to look around for a way to remove this terrible attribute from the required folders. Or if you know how, then you will save my life .
Cheers,
Old 30-12-2008   #13
Originally Posted by mazen_094 View Post
Ok man,
Cheers,
You are exactly right for this problem.I met this problem alot of times
400s, box, halted, relook
