Timer Recording and SoundSupport forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers. | |
| Member Join Date: 08-11-2008 Location: London, UK
My System: AB IPbox 9000HD, only a fixed dish for now.. |
Has anyone noticed that when a timer record is set on a channel that has more than one sound channel, for example BBC HD, (has Dolby Digital, and plain stereo) it will always record only the second channel (not Dolby Digital.) Sometimes this channel has the audio description, so you cannot turn it off if you dont want it. Sometimes the BBC SD programmes have the normal sound on the first channel, with the audio description on the second channel, so you get only the audio description. I have been unable to find any way to set which audio channel to record. Has anyone else noticed this, and found an answer? If you record manually, you can select which sound to record. | ||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | You havent mentioned what image you are using on your reciever? There aren't that many Cuberevo / AB IPbox 9000 HD users here on the forum. I just got mine recently and have not noticed the problem you mention. I've been using an Enigma2. | ||
| recording, sound, timer |
