ABIpbox - Visionet 7500s - Relook 200s ... etc 200swork with Cccam 2.09 etc ... How
Support forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers.
Old 09-04-2009   #1
My System: MULTIPLE
Hello,
Is there anybody out there who can give me a definite positive answer in the following question:
Can ABIpbox - Visionet 7500s - Relook 200s ... etc 200s work with Cccam 2.09 etc ... How is it set up? Are the settings the same as the dream boxes settings? (var/etc)
My receiver works with Enigma 2009 ABIpbox 200s (with out usb,hdd)
I have searched all forums and did not find an answer.....
Is there anybody out there??????
kahkon is offline   Reply With Quote
Old 10-04-2009   #2
tomthebomb1968's Avatar
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
If you are using the Abcom enigma image you need to put the All in One(AIO) update addon into your box. Extract the .ipk file and ftp it to the tmp directory.
Press blue button to enter te AIO menu and press red button for ipk.
Select /Available Packages[Feed: TEMP] its the second one in the list.
Just install it and when its done you will have the updated AIO with settings/cams etc now downloadable.
tomthebomb1968 is offline   Reply With Quote
The Following 2 Users Say Thank You to tomthebomb1968 For This Useful Post:
kahkon (12-04-2009), kamarat (4 Weeks Ago)
Old 13-04-2009   #3
My System: MULTIPLE
Thank you for the quick answer, I use ABipbox programme.
.jpk AIO is installed When I rebooted the receiver, I saw newcamd and some others, I did not see the Cccam can I installe it manually and if so in which folders?
Is there any other way?
Thank you
Old 13-04-2009   #4
It should be there m8 if you have the updated AIO panel.
1/Press Blue
2/Press Red fot IPK
3/Scroll down to Addons and select
4/ Scroll to second page/or right arrow for page jump
5/ Scroll to cam you want/press ok and a green tick appears
6/Press red to auto install the cam.
ABIpbox - Visionet 7500s - Relook 200s ... etc 200swork with Cccam 2.09 etc ... How-osdshot-png   ABIpbox - Visionet 7500s - Relook 200s ... etc 200swork with Cccam 2.09 etc ... How-osdshot2-png   ABIpbox - Visionet 7500s - Relook 200s ... etc 200swork with Cccam 2.09 etc ... How-osdshot3-png   ABIpbox - Visionet 7500s - Relook 200s ... etc 200swork with Cccam 2.09 etc ... How-osdshot4-png   ABIpbox - Visionet 7500s - Relook 200s ... etc 200swork with Cccam 2.09 etc ... How-osdshot5-png
The Following User Says Thank You to tomthebomb1968 For This Useful Post:
kahkon (13-04-2009)
Old 13-04-2009   #5
My System: MULTIPLE
1/Press Blue
2/Press Red fot IPK
Tank youvery match for the reply.
I will reinstall it and do it from the beggining.
thank you
Old 13-04-2009   #6
My System: MULTIPLE
thank you
MY FRIEND EVERYTHING YOU TOLD ME WAS RIGHT BUT.....
YOU DID NOT MENTIONED ANYTHING ABOUT CONNECTING TO INTERNET....
I AM NOT STUPID (I THINK....)
THANK YOU.
Old 14-04-2009   #7
Are you sorted now?
kahkon (14-04-2009)
Old 14-04-2009   #8
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
You could try other images. I've had everything on mine. I finally settled with Evolution 2.1 from the Satkeynet team.
You will find all the images you need for your IPbox over at _www.denktenk.com.
The SIF images are quite good, although i did have problems with emu installs on 1.9.3d.
The modified version of Gemini 4.60 also works extremely well. I don't mind using it on my IPBox as its a bit of a kick in the teeth for the Gemini team as its not being run on a Dreambox
Nano
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 14-04-2009   #9
My System: MULTIPLE
Are you sorted now?
I am trying to find out how the Cccam works, It is something new to me. It has many differences due to dreambox I have a 500s server and one of the ipbox is client.... I am trying make them work. To the others ipbox I amm trying to put other images but I have a long way to the top
Thank you very match for helping me
Old 14-04-2009   #10
My System: MULTIPLE
Nano
I have tryed Gemini but I couldn't make it start. It freezed when it displayed the gemini icon after reboot. I don't remember which version but I downloaded from the site you suggest.
I am trying evolution 1.2 in an other ipbox
thank you for replying we will be in touch
Old 14-04-2009   #11
You may have problems with the remote on some DM modified images, I.E it doesn't work.
You will need to change the machine ID to either a DM500 or DM5600.
To do this power up your ipbox holding the right key at the same time. This will then give you a menu with loads of machine IDs to try. DM500 & 5600 work the best from past experience.
After you have changed the machine ID the image will report the box back as which ever unit you have changed the ID to, and most importantly the remote will work.
make sure you change it back to IPbox 200 if you go back to a DGS image.
Another work of precaution on enigma images is try to not let the Var get more than 50-60% full as it can cause problems and slow response times.
If you add something like Cccam 2.0.11 and want to delete it you will find that it will not delete from the blue button. You have to physically remove it using an FTP client
Nano
The Following User Says Thank You to nanochickin For This Useful Post:
kahkon (14-04-2009)
Old 14-04-2009   #12
the ipbox will connect with the same cfg file you would use in a 500, no difference.
kahkon (14-04-2009)
Old 14-04-2009   #13
Thats probably the only one I have not had on mine, Whats it like for stability. I have been using the Abcom iimage as it its rock solid, honestlty has never crahed. Using it as a server only now most of the time and its been great.
kahkon (14-04-2009)
Old 14-04-2009   #14
My System: MULTIPLE
thank you very match ... you are very good!!!! Now I have work for the next month
Old 06-05-2009   #15
It can be a little hit and miss and does sometimes freeze but on the whole its not bad
I would say its about as stable as most Dreambox images were about 2 years ago. Not fantastic but getting better
tomthebomb1968 (08-05-2009)
200s, 200swork, 209, 7500s, abipbox, cccam, relook, visionet
