Can anyone help me...CubeCaFe250
Support forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers.
Old 26-05-2009   #1
My System: dailup
my CubeCaFe250S does not accept any images only Fantacy & hayland or
ooficial images .
Enigma images or abcom download completed But the device stop on boot and the tv Screen displaying the logo of the Team i Changed to all (mID) Nothing has changed.
Highland & Fantacy Work well.
THOR Neutrino & Enigma image the device stop on boot ant the tv Screen displaying the logo of the Team Please help . This happened after jtag .
Can anyone help me .
murad2000 is offline   Reply With Quote
Old 26-05-2009   #2
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
If its anything like the IPBox 200s you will need to change the uboot file as the Highland and Thor images are not Enigma images they are Neutrino ones
Once you have installed the uboot file, select the image file, start the loader and then Press OK on the receiver.
This is assuming you are using the flash tools loader and a serial cable. Serial seems to be the best method to use on these boxes
Normally you will find the uboot file in with the new image folder unless ( Once unzipped) If the image has the word "All" in the file name then you just need to use that one, you won't need to install the uboot file first.
I can recommend the Powerboard Enigma and S.I.F Images for the IPbox
_http://ou-powerboard.gmc.to/images/index-ipbox.html
_http://forum.sifteam.eu/
Please remember that the ABCom Ipboxes are the same units as the CubeCafe units just with a different brand name on them so eithyer image will work
Hope this helps mate
Nano
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 26-05-2009   #3
My System: dailup
I tried everything the same problem thanks to reply my dear friend .
Old 26-05-2009   #4
Suggest you have a look over at Denktenk.com or dgstation-forum.org you may get more help there
I don't think that these boxes are that popular here in the UK in all honesty so help may not be as forthcoming as say with the Dreambox
As far as the machine ID is concerned if your using an Enigma image like SIF, Gemini, Nabilo you need to set the machine ID as a DM500 or DM5600.
For ABCOM Enigma image or Neutrino images you need to select IPBOX 250 / DGStation 250/ Cubecafe 250
Nano
Old 28-05-2009   #5
My System: dailup
mecubecafe250
