ipbox 200s help
Support forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers.
Old 11-06-2009   #1
My System: softwares
ipbox 200s help
hi i have this ipbox200s and i cannot put cc cam in box how do you do this and does it work with a free derver
thanks hope some help
tony
harbat000 is offline   Reply With Quote
Old 11-06-2009   #2
tomthebomb1968's Avatar
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Heres how with abcom enigma image
ABIpbox - Visionet 7500s - Relook 200s ... etc 200swork with Cccam 2.09 etc ... How
tomthebomb1968 is offline   Reply With Quote
Old 11-06-2009   #3
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
It would also help if you let us know what image you are running on it
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 15-06-2009   #4
ipbox200s re
hi thanks for that file now im using the original enigma in box
what loader it uses this box to make new addons this box is so tricky
in box available packages are empty
thanks
tony
Old 15-06-2009   #5
You need this to send new images to your box
Don't bother getting the original image to work with cccam, just install something like SIF 1.9.3 and you can just download them from the blue button
This will only work with a Null modem cable
Old 15-06-2009   #6
You will need the usb vesta driver for flashtools unless thats in the zip file too, but windows should search for it itself, allow it to search online
200s, ipbox
