Relook problemSupport forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers. | |
| Regular Member Real name: Steve Join Date: 14-04-2009 Location: Co. Tyrone
My System: DM500s, DM7020si, DM600s pvr, 1m Triax Advent 9415 lappy |
Hi.. My best pal has a relook 400s reciever He is using a ccam 1.7.0. The image is fantasy with 2.13.6-neumo This reciever has a dual tuner and thats why he is using this image.. Is there a newer image that can be used on this reciever which will allow him to update his cccam as he is getting alot of freezing on all sats.. Any help would be greatly appreicated,, Thanks Steve | ||
| Specialist Contributor Join Date: 09-02-2008 Location: Newtownabbey, near Belfast, Northern Ireland
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east. | I have mine running on enigma now but you loose 1 of the tuners. Support stopped for DGS images after CCcam 2.0.0. Anything later gives freezes every 10 seconds or so. He will need to flash it with an "All" image which will have the correct bootloader, if he uses one of the "noboot" images going from DGS he will have an endless bootloop. I used the AbCom enigma on mine for about a year and its very stable, but I have been using the latest SifTeam image now for about a month as it has both cardreaders enabled. Its pretty stable too. And all the latest cams and configs on the server for direct download to the box. | ||
| The Following User Says Thank You to tomthebomb1968 For This Useful Post: | wannabee (25-07-2009) |
My System: DM500s, DM7020si, DM600s pvr, 1m Triax Advent 9415 lappy | Thanks for reply Tom.. Are you still able to use the dual tuner with this..?? I mean are you able to record one thing and watch another.. ?? Thanks again.. Steve | ||
| Member Join Date: 30-07-2004
| problem, relook |
