Tutorial in Cardsharing between Relook 400s/DreamboxSupport forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers. | |
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
Here is a simple configuration in howto setup a working cardsharing configuration between the Relook 400s as client and a Dreambox 7000 as server. This configuration is based on a simple card with no BOXID, other sharing methods will work for other providers with some changes, eg N*S Example below is for CanalSat France package: Server : - Dreambox 7000s - Image : gemini 2.20 - Emulator : newcamd 6.04 cardserv - IP : 192.168.0.5 Name of the server: z Client : - dg 400s - Image : ronaldd 1.03 - Emulator : newcamd - IP : 192.168.0.2 - Username : likvid - Password : likvid1 CARDSERV.CFG DESKEY = 0102030405060708091011121314 SERVER_NAME = z DEBUG_PORT = 14000 ENTITLEMENT_PORT = 14001 ADMIN_PORT = 14002 ADMIN_PASSWORD = secret 00 00 00 00 00 00 00 00 00 00 00 00 00 00 USER = local local lan localhost 12000 au USER = likvid likvid1 lan 192.168.0.2 12000 au SERIAL_PORT = 0 TCP_PORT = 10001 EMM-G = no EMM-S = no EMM-U = no SPECIAL_FEATURES = yes SERIAL_PORT = 1 TCP_PORT = 10000 EMM-G = no EMM-S = no EMM-U = no SPECIAL_FEATURES = yes NEWCAMD.CONF DEMUX_API = 2 BOX_TYPE = DM7000 CONTROL_WORD_DEVICE = CA CA_API = 3 GTX_OUTPUT_MODE = 4096 PMT_UPDATE_WATCH = yes EMU = yes PREFER_EMU = no DISABLE_CAM = yes CAM_CASYS = 17 AU = yes SHOW_ALL_CA_SYSTEMS = no OSD = none DEBUG_ECM = no DEBUG_EMM = no DEBUG_CWS = no DEBUG_CAM = no DEBUG_CAM_HEX = no SHOW_CW = no SHOW_PAT = no SHOW_PMT = no SHOW_ECM = no SHOW_CAT = no SHOW_EMM = no SHOW_CWS_ECM = no SHOW_CWS_EMM = no EMM_REPORT_WRONG_SIG = no OSD_WAIT_TIME = 2000 DEFAULT_CW_DELAY = 0 RELOAD_CONFIG_ON_ZAP = yes RELOAD_KEYLIST_ON_ZAP = yes CWS = localhost 10000 local local 0102030405060708091011121314 wan z CWS = localhost 10001 local local 0102030405060708091011121314 wan z CWS_CONNECT_TIMEOUT = 20 CWS_INCOMING_PORT = 12000 CWS_DEBUG_PORT = 12005 ADMIN_PASSWORD = secret 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Configuration RELOOK DG400S on/off : on hostname : 192.168.0.5 port : 10001 (the upper slot of the DM7000S) username : likvid password : likvid1 deskey : 0102030405060708091011121314 wan z on/off : on hostname : 192.168.0.5 port : 10000 (the lower slot of the DM700S) username : likvid password : likvid1 deskey : 0102030405060708091011121314 wan z | ||
| The Following User Says Thank You to Likvid For This Useful Post: | YanniG (11-10-2007) |
| Member Join Date: 28-12-2006 Location: Sweden
My System: 2 sattelite dishes with two LNB's each. Relook400S receiver |
Hi, I saw your tutorial about sharing between Relook and Dreambox. However, the image you are using is ronaldd 1.03. What image do you today recomend for CS using newcamd? | ||
| | #4 | |||
| Second choice would be Gbox, but there is alot of scam in those groups, people trying to get a free ride on other people by using a expired or fake card. | |||
| | #5 | ||
My System: 2 sattelite dishes with two LNB's each. Relook400S receiver | Tack för infon, jag skall prova detta men, jag har ett problem som uppträder på alla DGS baserade images jag provat (orginal, Highland, FantacyTeam, Ronaldd, Neumo och FunTeam). Efter det jag har startat upp Relook400S och sökt kanaler, satt preferens m.m. så fungerar burken. Efter en tid stänger av burken via stand-by knappen på remotecontrollen för att sedan dagen efter eller senare starta burken igen via remote. I dessa lägen kommer jag alltid fram till "the format of stored database is different from the current programs database (sored unknown, required 1.17)" och jag får två alternativ 1, fortsätta och därmed radera all information eller 2, ladda en sparad databas via PC tools. Vad gör jag för fel, databasen är 1.17 (vilket jag kan verifiera genom att se system setting) men ändå får jag gå genom proceduren. Vidare kan jag inte gå in i PCeditor vid starfrågan utan det kan jag bara göra senare då jag väljer PCEditor under "UBB läge". Detta är ett stort och irriterande problem... | ||
| | #6 | |||
Men flasha om den med en full image, dvs en 8MB image och ladda in den nyaste bootloadern. | |||
| | #7 | ||
Hej, jag upptäckte att tunern hade svårt att driva en större disk (Hitachi) men då jag tog bort den så fungerade allt som det ska. Efter det satte jag in en mindre disk (10Gb och allt fungerade och nu har jag provat mig upp till en western Digital (200 Gb) och problemet är försvunnet. Tack för dina förslag. | ||
| | #8 | ||
My System: 2 sattelite dishes with two LNB's each. Relook400S receiver | Hej, på Dreambox har man väl nadra portar såsom 18000 eller 18001, när jag kör din konfig men med dessa portar på min Relook får jag ingen kontakt... | ||
| | #9 | ||
| Member Join Date: 19-09-2005 Location: england/uk
My System: force1145s dragoncam dreambox 5620 dbox2 1.2 metre dish motor cryptic hh computer xp2000 + 3k modem connection and mutant relook 200s dreambox500c |
hi likvid is the configaration the same for 200s as is for 400s+dreambox sharing.i want to link my 200s with my mates 7020 dreambox using a wireless linksys lan bridge.my mate lives three doors up from me and we already share the same brawdband connection.any help would be great m8. | ||
| 400s or dreambox, cardsharing, relook, tutorial |
Similar Threads | ||||
| Relook 400S, the world's first Linux Twin-Tuner PVR | Likvid | Relook, IPbox and Cuberevo receivers | 25 | 25-01-2006 10:51 PM |
| Relook sites and forums | Likvid | Relook, IPbox and Cuberevo receivers | 0 | 06-12-2005 01:36 PM |
| relook 400S - 200S | gilles.R. | Receiver software, international Section | 1 | 16-10-2005 11:09 PM |
| Link to a Tutorial about Dreambox 7000 | DHeart | Dreambox General | 8 | 03-07-2004 04:50 PM |
