relook 200s problemSupport forum for the Relook Twin Tuner Linux Satellite Receiver, plus the AB IPbox and Cuberevo receivers. | |
| Member Join Date: 11-01-2006 Location: NW
My System: db7000 90 CM triax moteck motor well trying to install it ! |
hi can anyone please help , i have set up a USA relook here in UK- put the img highland on. to PAL everything works apart from when i have scanned via the search for channels I cant get any pictures - I only have the sound working can some 1 please assist. or offer any advise. | ||
| Member Join Date: 29-05-2007 Location: UNITED KINGDOM
My System: I HAVE MUTANTS 200S THAT IS CONECTED TO THE INTERNET. | hi can someone advice me on how to install gbox on my mutant 200s. i accidently errased the initial installation. pls come to my rescue. | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| Here is a working gbox_cfg file for Relook 400s, try it out. # gbox config file # Task type # 00 ** normal mode gbox mode (no season, use Multicam instead) # 01 ** Season Emulation in a Irdeto allcam chid 0602 nonZ # 10 ** Season Emulation in a Irdeto allcam chid 1702 nonZ # 11 ** Season Emulation in a Irdeto allcam chid 1702 Z # 12 ** Season Emulation in a Irdeto allcam chid 1722 Z # 13 ** Season Emulation in a Irdeto allcam chid 1762 Z # ** *1 Com port to use for season emulatiom (1 or 2) # ** 0* Use CTS fr RST detectio # ** 1* Use DCD fr RST detectio # ** ** 9600 = Baudrate to be used (working only on dbox2) W: { 00 00 } 9600 # gbox working mode # 00 pure Emu # 01 pure SoftCam (when card inside), Emu (when no card inside) # 02 pure Net Client # 03 Mixed mode !!!!! always use this !!!!! G: { 03 } # Display ECM messages on Konsole # 00 don't show any ECM's # 01 show only valid ECM's # 02 show valid and bad ECM's with complete data display C: { 01 } # Display EMM messages on Konsole # *0 don't show any EMM's # *1 show only valid EMM's # *2 show valid and bad EMM's with complete data display # 1* Log any tier change on PW-Nagra-17xx cards into /var/keys/pwupdate.log M: { 01 } # AutoUpdate # 00 is ignored (default) # 01 enable AU # 02 Auto AU !!!!! always use this !!!!! A: { 02 } # Key update # 01 update only new keys, default setting # 02 update all keys (used for valid PMK checking) U: { 01 } # Hash pids # 00 hash all pids, DO NOT USE THIS OPTION, IT IS ONLY FOR TESTING STUFF # 01 hash only pids with implemented algos and available keys !!!!! always use this !!!!! H: { 01 } # Key files folder # 00 keyfiles in /var/keys # 01 keyfiles in /var/tmp T: { 00 } #NDS overclock #F: { 58 } 02 #6.30MHz #F: { 58 } 03 #5.25MHz # On Screen Display for the Multysystemcam on com1/com2 # 00 No OSD (default) # 01 display Smartcard messages in Neutrino # 02 display Smartcard messages in Neutrino new nhttpd format # 03 display Smartcard messages in Enigma # mypass (use user=root and pass=mypass for nhttpd) O: { 00 } 192.168.1.3 # Logger and NET-mode UDP port Init # 00 do not init UDP port # 01 Init UDP port for IP, port, UDP #F: { 01 } /dev/shm/pmt.tmp # Trace/Debug # xx yz ; xx=00 no konsole output # xx yz ; xx=01 konsole output # xx yz ; y=0 debug output (don't use) # xx yz ; y=1 no debug output # xx yz ; z=0 ouput to konsole # xx yz ; z=1 output to /var/tmp/debug.txt # xx yz ; z=2 Output to UDP (to capture with gboxt) Z: { 01 12 } 192.168.1.2 8024 # *x ** ; x = device nummber to be used (0= default) # D* ** ; force use of /proc/bus/gtx for cw write operations (in the dbox2 the gbox writes directly the CW's, 00 is the recommended mode ! No drivers are required) use D* ** ONLY if you have Problems. 0* ** should be prefered !!! # F* ** ; write CW's in both devices (used for PVR in STB04xxx devices) # ** y* ; y=0001b (0x1*) use slot1 as Multicam (only on STB04xxx) # ** y* ; y=0010b (0x2*) use slot2 as Multicam (only on STB04xxx) # ** y* ; y=0011b (0x3*) use slot1 and slot2 as Multicams (only on STB04xxx) # ** *z ; z=0001b (0x*1) use com1 as Multicam # ** *z ; z=0010b (0x*2) use com2 as Multicam # ** *z ; z=0011b (0x*3) use com1 and com2 as Multicams # ** yz ; yz=00110011b (0x33) use slot1+slot2+com1+com2 as Multicams # ** *z ; z=0100b (0x*4) invert CTS detection on com1 # ** *z ; z=1000b (0x*8) invert CTS detection on com2 # example: yz = 0x0A = 00001010 (use com2 with inverted CTS detection line) V: { F0 30 } | ||
| 200s, problem, relook |
