Digisat Pro...
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 01-05-2008   #1
My System: None
Digisat Pro...
Does anybody know if the Digisat Pro meter displays sat info? Or am i i best forking out for a Lacuna meter or similar?
Cheers.
Cargosat is offline   Reply With Quote
Old 01-05-2008   #2
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
no it doesn't tell you what satellite you have aligned to, only just a signal strengh bar on an lcd screen
for anything like satellite NIT readout you will need a meter like the satlook micro, horizon hdsm v3 or wolsey/lacuna meter
Old 12-09-2008   #3
My System: Sky-HD
Mine does, for example if i am pointed at 5.0e the display says "KRRT 4.8E" I have a pro 204
gunn1e is offline   Reply With Quote
Old 12-09-2008   #4
rolfw's Avatar
Real name: Rolf
Can't find that model on the emitor site, have you got the spec?
Rolf
Old 12-09-2008   #5
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
Mine also does not. And btw, it's not a good investment I believe. Does same, as cheap finder.
BombedOne is offline   Reply With Quote
Old 12-09-2008   #6
My System: Sky-HD
This is mine, _http://www.swires.com/pdf/digisat204ds.pdf
Last edited by satelliteman; 12-09-2008 at 12:58 PM. Reason: Live Link Deactivated - SM
Old 12-09-2008   #7
My System: dream5000 v box 1metre motorised
Try the Satcatcher exel TV. Its got all the European channels in it, got a speccy, and will show picture and sound on the FTA channels. It also drives a diseqc motor! Comes with a handbook in english - well Yorkshire English actually - and a CD to write or edit the channel plans. We use them for all our work, including motorised.
don coolman is offline   Reply With Quote
Old 12-09-2008   #8
rolfw's Avatar
Real name: Rolf
OK, thanks, but that isn't the Digisat Pro the original poster was talking about, yours is a Swires meter and probably quite a bit more expensive.
Yes, it is a nice little meter, have seen them in action and was very impressed, but we are talking about a meter which costs in the region of £50, not £250.
Rolf
Old 13-09-2008   #9
Hi Rolfw,
Yes its about £445.00+VAT
Old 17-09-2008   #10
patmos's Avatar
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst
don coolman. why is must be the 22khz ON for KU universal LNB to work on this meter. Is this normal? For C band no 22KHz is needed.
patmos is offline   Reply With Quote
Old 17-09-2008   #11
rolfw's Avatar
Real name: Rolf
C-Band LNBs are single band, whereas a Universal LNB is dual band and uses a 22Khz tone to switch to high band.
Rolf
Old 17-09-2008   #12
patmos's Avatar
Thanks I understand now. Higher frequencies (LO 10600) needs that band switching.
digisat, pro
