22-12-2008
#1 |
| Member
| Wrong Firmware on Satlook Digital NIT | | Hi By mistake i uploaded wrong firmware to a Satlook Digital NIT I am trying to upload the correct firmware with folowing procedure: - I connect the serial RS 232 cable.
- I start the FDL.exe program select Com port and push the send firmware button.
- I push OK and connect the power cable.
- I get connected to the instrument and a window opens and I choose the firmware to be uploaded push OK and instead of uploading it I get disconnected from the instrument ( a massage appears “lost conduct with instrument”
Wondering if there is a way to flash / reset or erase the instruments memory so as to load proper firmware. I send email to emitor and they told me to check my power supply. My power supply works just fine. Thanks |
