Has anyone tried one of these Sat MetersSection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Regular Member Join Date: 01-01-2000 Location: scotland and greece
My System: protek 9600ip echolink el888 starsat super 650ci 1.8m precision dish and standalone 36v positioner. |
Anyone know anything about the "3.5" Color LCD Pro Digital Satellite Finder Meter TV2" Item number: 250349631913 on Ebay I am not a professional installer but would like something a bit better than my small sat finder I currently use for tweaking my dish. | ||
| Dreambox 500s, Protek 9600ip, echolink el888 (not used) precision 1.8m motorised dish. standalone positioner(in scotland)moteck 2100a(in greece) | |||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | It's basically a portable Comag/ Silvercrest type receiver with an LCD & battery pack/ charger.. put together as a meter .. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | yes, I was going to say it's only a satellite receiver with a in built screen. May show the SNR & power strenghts as do high end receivers. Still not a bad price | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | I think it would come down to what it's like to use like that .. battery life/ recharge time, tuner sensitivity, screen in daylight, if you can use the lcd on its own & output the video/ audio (the English is not very good as to whether it can), if it all works fairly well and there are more options on the 3 digit display then it's an option.... or if not ... you could use it as a portable stb (with monitor if your eyesight's OK) | ||
| | #5 | ||
My System: protek 9600ip echolink el888 starsat super 650ci 1.8m precision dish and standalone 36v positioner. | Thanks guys for the comments. Agree it is basically a mini battery operated sat receiver (3 hours on external use). Below I have listed the spec as detailed in the user manual. From what I can see in the manual it only has sig intensity and quality readings but no ber reading. Apparenty u will get a picture on the screen with 35% quality reading which I thought was quite good. Not sure how important the lack of BER is for me given I am only likely to use it for my own motorised system and re-alighning family sky systems. Obviously the price is the big attraction although the £120 quoted on Ebay Any further comments from u guys would be appreciated Display screen,TFT 2.5” / 3.5” pixels,Battery pack DC7.4V 4000mAh A/V output,Video RCA/S-Video,Audio RCA left/right/stero channel Input impedance 75 (F style),Input frequency 950~2150MHZ Input signal strength-65 ~-25dBm Symbol Rate 2-45MbaudsMCPC,SCPC compatible EB/O Threshold 4.1dB Demodulation QPSK ,Input voltage DC8.5V Video decode ISO/IEC 13818-ZMP @ML NTSC/PAL size 165x125x80mm Audio decode ISO/IEC 13818-3Layerl & 2 Weight 780g(with battery) | ||
| meters, sat |
