What is the best meter to use?Section for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Regular Member Join Date: 26-01-2008 Location: Cornwall UK
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 |
Can anyone recommend a meter for aligning a sky mini dish? It has already been installed but im missing some channels. What is the most user friendly economy priced meter do they have to be connected to the reciever as well as the dish? | ||
| Guest
Posts: n/a
| Have you considered Interference as a cause rather than misalignment? What Channels are missing? Are they things like Flava, Bliss, True Movies? OTOH, if it is an alignment issue, just use the Receiver as a Meter, as you are only going to be the tiniest amount out. | ||
| Last edited by guest; 17-01-2009 at 04:01 PM. Reason: Speling Eror ............ | |||
| The Following User Says Thank You to For This Useful Post: | divibi (17-01-2009) |
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #5 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | hi i am mainly missing the world movies channel see this _http://www.satellites.co.uk/satellite/b-sky-b-digital-28-2-east-general/142823-where-world-movies-channel-gone.html also setanta has bad reception but i know thats on 28.5E any ideas what i should do | ||
| | #6 | ||
| Guest
Posts: n/a
| Yes. Just move the Dish a tiny bit further East (millimetres only). As you are virtually aligned (or you wouldn't get anything at all!), the misalignment (I think we can now assume that is the real issue) is small - If you have a helper, you could even determine which way to move the Dish before actually loosening any clamps by gently pressuring the LNB arm one way then the other (and also up and down) whilst your helper tells you "better" or "worse" using the Signal Bars on the Box. Don't block the signal while you are playing, obviously! A Zone 1 Minidish should be perfectly ok for you in Cornwall (assuming that is what you have got!). If there is no improvement, trying a different LNB may help as performance can drop off at the very edges of the band and World Movies is right oop top. | ||
| Last edited by guest; 18-01-2009 at 11:32 AM. Reason: Brilliant afterthought. | |||
| | #7 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Can you explain what this means "A Zone 1 Minidish"? also what channel should i put the reciever on to see signal % while i am trying to realign it? | ||
| | #8 | |||
| Guest
Posts: n/a
| North of UK and Northern Ireland generally require Zone 2, but much of central and southern UK can manage with the smallest size. As you are in Cornwall, the smaller one is sufficient. I merely mentioned it as there are places in the country that are borderline and sometimes upgrading to a Zone 2 Dish would help. Do you have a SkyBox or are you only using your Dreambox? If SkyBox, then the Box listens by default to 11778 V and you don't need to select a Channel. If Dreambox, select any Eurobird Channel - preferably one that is pixellating. I have to say, if you can drive a Dreambox (I haven't plucked up the courage for that yet!), fine tuning a Dish should be a doddle | |||
| | #9 | ||
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | hi erukus you could always buy one of those cheap needle meters maplin do them for £15 ,probably be ok for peaking the dish now its on the right sat good luck | ||
| | #10 | ||
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8 | Ok thanks for the info one final question I have to ask as to the meaning of "pixelating" Intuitively i would say meaning some kind of picture being displayed as opposed to blank screen???? | ||
| meter |
