Equipment for satellite installer
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 04-02-2009   #1
Heathrow Newbie's Avatar
My System: Newbie looking to start up in this industry
Just out of curiousity I have been looking on the net for the right equipment but with so many different models to choose from I am lost so was hoping you experts could point me in the right direction.
I have been looking at meters and really don't have a clue!
Ladders not sure what height I should get?
Drill I have seen a nice b&d I liked but don't think it is suitable.
Last but not least a safety harness! Think I am ok on this one actually!
So if you could recomend me on the above I would greatly appreciate it.
Mark
Heathrow Newbie is offline   Reply With Quote
Old 04-02-2009   #2
satelliteman's Avatar
Real name: Paul
Installation tools required for sky installs:
>Double or Triple Extension ladders to BS-EN131
> Single section roof ladder
>Safety Harness and ropes
>24v SDS Drill, drill bits 8mm x 450mm 10mm x 450mm 10mm x 160mm, 10mm x 1000mm
>Alignment meter (Horizon seem a fairly good satellite meter for a starter), See _http://www.horizonhge.com/products_digi_sat_hdsm_usb.html
>A selection of hand tool and spanners.
satelliteman.
An Installers Choice
Follow us on
Old 04-02-2009   #3
rolfw's Avatar
Real name: Rolf
Regarding ladders, get what you feel comfortable with, both in reach and weight.
I have a set of Youngman trade triple section ladders 13 rungs per ladder, equivalent to the 12 rung modern version, mine are slightly closer together and slightly wider. I'm looking for a second set (I gave my narrower set of Youngmans to my brother in law), but want them with section locks which mine don't have. I bought an extending roof ladder, as I was finding that my single was too short for many rooves, they are however quite heavy to manoeuvre.
Don't skimp on your drill, I have a Bosch GBH and love it, this one has been going for around eight years and still works well, my very first drill (Atlas Copco) was horribly under powered and I needed to upgrade after a year or so.
Safety harness and ladder fixing kit can be bought as a package from wholesalers like Alltrade, or direct from one of the safety companies.
The meter is probably the most crucial piece of kit, worth spending some money on, although even if you buy a budget model to start off with, they normally have a reasonable second hand value. Do you plan to do aerials as well? If you do, then to buy a meter with terrestrial digital capabilities takes you up to another level.
Oops too slow, was trying to do three things at the same time, Paul beat me to the tape.
Rolf
Old 04-02-2009   #4
Ok this is what I have found are they good prices?
10.2m TRIPLE EXTENSION LADDER BSEN131 TRADE EXT GBX340 £115
4.5m Single section roof ladder £89
BRITANNIA SUPER SAFETY HARNESS + LANYARD + KARABINERS £65
BOSCH GBH 24V SDS PLUS HAMMER DRILL 2x 2.6ah NiMH - NEW £250
Horizon Digital Satellite Meter USB Plus- Brand New
£350
Ok this is what I have found so far quite expensive but well woth it! I do have a few of my own tools which i am preety sure is sufficent.
Rolfw I will do terrestrial to mate as long as the work is there I will bw there to do it!
Old 04-02-2009   #5
rolfw's Avatar
Real name: Rolf
Not sure whether the roof ladder will be long enough, my single is just over 14ft and comes up too short on quite a few jobs, also not a lover of the box aluminium hooks, they have a lot of give, great from braking clay tiles and slates as you put weight on the ladder and the whole thing drops.
The harness looks good, but you'll need some other kit as well, such as ropes, a cow's tale and some ladder straps and eye bolts. I also use a ladder mate and microlite standoff.
The second kit down on this page has most of what I have: _http://www.county-safety-services.com/_docs/kits.htm
Digital terrestrial work will require a meter, probably more important to have a good one than on satellite installations.
Rolf
Old 04-02-2009   #6
Real name: Paul
Always used Lansford Access.
Trade or Industrial ground ladders: _http://www.ladders-999.co.uk/ladders_alloy.htm
Single or two section extending roof ladders : _http://www.ladders-999.co.uk/ladders_roof.htm
HSE roof ladder kit, comes with the standard ladder in £256+vat (shop around): _http://www.county-safety-services.com/_docs/kits.htm
SM
satelliteman.
Follow us on
Old 04-02-2009   #7
Robbo's Avatar
Real name: Mark
For a budget meter, I would not recommend the Lacuna MK4 The battery life is rubbish, it can't identify the satellite and doesn't give absolute dB uV readings. I did try out a SWIRES DIGISCAN-007 at Alltrade and it looks like it wouldn't be a bad buy for around £300 to £400, with spec anal.
I use a 6kg sds drill (mains) that cost about £40, it does the job and goes through brick like butter, bit of a pain being tethered to a cable though, but it's cheap.
Old 04-02-2009   #8
So a longer roof ladder!
A better harness kit. But £250 seems alot!!
Drill is good. Dont mind looking for 1 that is a little cheaper tho.
Meter is good and I am happy with the price.
All in all I would be looking to spend £800 on tools and accessories!
Old 04-02-2009   #9
rolfw's Avatar
Real name: Rolf
The harness kit isn't better, nothing wrong with the harness you mention, but on its own it is worthless, you need the relevant ropes and accessories.
Don't go cheaper drill wise, a false economy and although Robbo gets away with a corded drill, it will become increasingly more impractical the busier you get and could be a problem when on building sites.
Rolf
Old 04-02-2009   #10
Real name: Paul
SDS Bosch24v and Ryobi24v.
_http://www.tool-net.co.uk/p-323189/ryobi-crh-240re-24v-sdsand-rotary-hammer-drill.html
satelliteman.
Follow us on
Old 04-02-2009   #11
jonwisbey's Avatar
My System: virgin v+ additional stb 10mb broadband freesat hd
i will be getting rid of my horizon in the next couple of weeks it has done me well and earned me enough lolly but im upgrading to a specy. if all you want is domestic satellite ie sky european and motorised its all good. but not so good for irs systems. i use the same type but aerial version as well that is also very good for domestic
these meters are entery level pro meters and new will cost you new about £600-£700 or for a about £1000 you can get a rover st2 specky £2000 rover st4
jonwisbey is offline   Reply With Quote
Old 04-02-2009   #12
Mod and septic resident
Channel Hopper's Avatar
I use a double set of roof/ridge ladders, as the van is too small for a single span, and a worn - flexible - motorcycle tyre 110/90x18) that can be put under the lower supports of the ladder to spread the load - especially after Christmas.
And, my twopence worth.
Grippy gloves for all work above gutter level (in this weather the insulated ones)
Draper combination open end/ratchet spanners in 10, 11, 12, 13 15 and 17mm.
A good tool pouch (and a soft synthetic belt) with separate hammer holster.
Trousers, preferably rip-resistant with knee/calf pockets.
Indoor shoes - never wear them outside, ever.
Good, light waterproofs
Even better steel toecaps, Timberlands are my choice of weapon and are down to 88 quid in the sales at the moment. They can last three years and dont mind the odd spin in the washing machine.
A washable blanket that you can throw under any place you might drill a hole, and then shake outside.
Old 04-02-2009   #13
@Rolfw - you haven't mentioned the ladder ground supports
Old 04-02-2009   #14
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Exclamation H&s test 1#
Just thought I'd get you started with some basic H&S.
.. Now...take your time and look carefully... can you see anything wrong with this picture, and if so.... can you list the points you think he might just be getting a BIT WRONG ... 1) 2) 3) etc......or... a) b) c)..........
(apart from the fact he's a roofer and not an installer- that doesn't count....... but probably explains it).
Equipment for satellite installer-idiot-roof-jpg
pedro2000uk is offline   Reply With Quote
Old 04-02-2009   #15
rolfw's Avatar
Real name: Rolf
Yep, mentioned my laddermate in the earlier post.
Rolf
Old 04-02-2009   #16
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
OK i'll give my two peneth here
As Rolf & Satelliteman has said you can't go wrong with a Bosch GBH 24v. I find mine useful as you can sling it so you can just throw it round your neck when your climbing up the ladder.
I also find an SDS nut runner a good idea to tighten up the wall bolts. Using your drill is definitely faster than using a spanner.
I use 3 different sets of ladders , 11 rung, 13 rung and 15 rung. I get the most use out of the 13 rung ones, the 11s are too short if your working on flats, ok upto the second floor though and the 15 rung ones are too heavy and only useful if your going past the 3rd floor.
A ladder stand off bracket and Ladder spurs are also a good idea
With regards to safety gear you will need a 20mm eye bolt and a 5 meter ratchet strap to tie your ladders to the building, this also takes all the flex out of the ladder when your climbing it.
You will need a rope to BS standard, a rocker, at least 4 lanyards, 3-4 karabiners and a good safety harness. I find the front fastening ones are the best as they are useful when working off a ladder if you need both hands
I got mine from screwfix if i remember rightly. Its a snazzy bright orange and yellow one
Oh yes and dont forget an Expandable Shock Absorbing Lanyard, very useful when you fall off a ladder
With regards to meters, i use a Rover DM16C Digimax which i think is the dogs danglies but unfortunately you won't get much change out of £2500 for a new one
Mind you the older Rover DL4 aren't bad if you can get hold of one.
As for the roof cat ladders a two piece ladder with lockable brackets is definately the way to go.
Nano
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 04-02-2009   #17
fantom007gr's Avatar
My System: DREAMBOX 7000
For
try to get the best equipment
there is an expresion :the most expensive is cheaper.
also have in mind that the customers they will junge you from the equipment you will have.
try to brake the avereage score.
they will advertize you farther.
this from an old dog.
fantom007gr is offline   Reply With Quote
Old 04-02-2009   #18
rolfw's Avatar
Real name: Rolf
As a matter of interest, does anyone here use "C" section ladders?
Rolf
Old 04-02-2009   #19
kenny1234's Avatar
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn.
If your planning to subbie your prob gonna need a Pda for them to download your routes to you
kenny1234 is offline   Reply With Quote
Old 04-02-2009   #20
WOW I am now getting spoilt for choice!! I am like a kid in a sweet shop! To be honest I would like to spend no more than £800. Bearing in mind I am new to this so don't think I will need the dbs equipment straight away!
Old 04-02-2009   #21
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
What an excellent thread! As im planning on going self employed.
I am currently doing an RDI digital installers course, and will be booking
courses with the CAI, as I have funding because I have recently been made
redundant.
I have a satlook micro and just bought a 2nd hand Promax 3 meter PROMAX PROLINK 3+ meter its got a black and white monitor.
Would the Promax be a good enough meter just to get me started?
CROSSBONES is offline   Reply With Quote
Old 05-02-2009   #22
Can't see why that meter wouldn't be any good Crossbones. Promax stuff isn't that bad if i remember rightly. I only ever used one once.
As long as it does power, Noise margin and BER it will do the job fine It would also be useful if it told you what satellite your looking at
Don't worry if it hasn't got a sat finder function on it as after a while you will find it quicker using the spectrum analyzer on it anyway
Can't remember the last time i used the Sat finder function
Make sure it also has a function to show the digital clusters and transmitter name (you won't need the transmitter name once you get to know the frequencies)
It used to show on mine Sutton Coldfield, Wrekin B, Ridge Hill and Brierley hill. Now it just shows West Midlands on all 4
I can recommend you grab hold of an aerial catalogue from your local supplier as it shows all the frequencies of all the UK transmitters.
The Triax catalogue is quite a good one as its only a small book that will fit in your pocket.
Nano
Old 05-02-2009   #23
rolfw's Avatar
Real name: Rolf
Likewise, I mainly use the Satlook NIT spectrum trace for sat finding, much quicker than the satfinder function on the ST4.
Rolf
Old 05-02-2009   #24
CROSSBONES's Avatar
Ok thanks guys, Ill probably end up selling the pair, when I get up and running, and hopefully earning loads of cash And buy a better newer meter.
I have got one of those Triax booklets Nano, as the Sales guy from Triax is on the RDI course with me, and he brought a load in for us. The UK factory is in Treorchy, Wales
Old 05-02-2009   #25
Real name: Paul
The PROLINK 3+ are good meters and well supported.
satelliteman.
Follow us on
equipment, installer, satellite
