Inclinometers and angle findersSection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Regular Member Join Date: 09-01-2005 Location: Bournemouth
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | | ||
| It's not what you know or who you know but what they know. | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Is it this one? Attachment 13763 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Just bought one, if anyone else is interested, please use the Ebay ![]() I normally use a spirit level, or inclinometer, but as John says, irregularities in the mast surface can make for some interesting readings. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Got mine this afternoon, you still need a spirit level, as the true horizontal plane needs to be found, so you sit it on the level and press the zero button and then you are set. Very strong magnetic base, so will sit on the mast securely and it comes with a little pouch as well. | ||
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | a silly thing but can it be used sideways on a pole to align t&ks up etc or is it just for horizontal stuff ? | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes, that's what it's for, that's why I mentioned the strong magnetic base for attaching to the pole. ![]() In fact it is predominantly designed for setting the angles on circular saws etc, but does this job well. | ||
| | #7 | ||
| Member Join Date: 11-08-2007 Location: Reading, Berkshire
My System: DM800 / DM7025 C/S 320GB HDD. Nabilosat Images, TD88 / 0.2dB LNB. DiSEqc TM2200(53e-58w). 500GB NAS Drive. | Hi, Quick question. Just picked a wixey angle finder up. Once you've calibrated it to the horizontal, does it stay true with constant use, and if not how often do you need to re-calibrate it? I ask, as i'm wondering whether to invest in a decent spirit level, or just borrow one for the purpose of setting it up. Regards. | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | It appears to, as I haven't checked mine since my last post and it is still set. You would have to make sure not to accidentally press the zero button. | ||
| | #9 | ||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | Had mine for a while, use it for all sorts of things, brackets, bending sheet metal, on a milling m/c, seems to stay calibrated, not had to replace battery yet but would not expect it to change | ||
| Oldgeezer | |||
| angle, finders, inclinometers |
