Lacuna mk4
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 17-02-2009   #1
gpage24's Avatar
My System: sky,Showtime,Supersports,Art,1.2 meter dish,Lacuna mk4 meter,Horizon ,satcatcher,
Lacuna mk4
Im using satmeter 302 editor from lacuna and im trying to input transponder settings for 16E w2 11449H 27500 7/8 for supersport.this is what im doing..( attached)
problem is when i load the data set and connect up to dish im getting no reading from the H transponder,, the V´s are ok, dish is aligned ok and giving a Q reading of about 68% when connected to the receiver.
Any ideas?
Lacuna mk4-untitled-jpg
gpage24 is offline   Reply With Quote
Old 17-02-2009   #2
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
How big is the dish? My guess is you need a 1.8 for that. Can you see any other horizontal transponder on that satellite? Astra 2D works the same here. Fair signal on vertical but is impossible to resolve horizontal.
Huevos is offline   Reply With Quote
The Following User Says Thank You to Huevos For This Useful Post:
gpage24 (17-02-2009)
Old 17-02-2009   #3
gpage24's Avatar
using a 1.1 its big enough here for supersport,,,but im a bit lost as to what your on about
Old 17-02-2009   #4
Robbo's Avatar
Real name: Mark
Huevos is simply suggesting that maybe your dish is not large enough to receive the the Supersport horizontal transponders on 16E and that there is nothing wrong with your meter setup. The figures you have entered look correct.
Can you watch the Supersport (horizontal transponder) channels through your TV?
The Following User Says Thank You to Robbo For This Useful Post:
Old 17-02-2009   #5
Looking at Lyngsat you are right on the edge of the footprint:
_http://www.lyngsat-maps.com/maps/ew2_wide.html
Old 17-02-2009   #6
gpage24's Avatar
yes the picture is fine ¡¡ but i reckon ut could be better,,just that the meter is hiting the H transponders eraticly,,,,cant get a lock on it,and also even with a 1.2 dish,,, verticals no problem...when dish connected to receiver getting 68% Q, it doesent ad up..sorry bout that Huevos im just a bit confused over this...
lacuna, mk4
