Satlook micro+ /G2 - charging behavior
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 21-03-2009   #1
My System: 4 x lnb, nokia receiver, satlook micro+/g2
Lightbulb Satlook micro+ /G2 - charging behavior
I bought a used satlook micro+. The seller told me he had trouble with charging, but suggested a running time of 30min for each charge.
The batterypack is new, they have tried changing it without any better performance.
The included powersupply is of the "transformesless"-kind I think.
The manual says, use no other than this one.. 13.8v
Using the included one, I only get 4 minutes of running time, no matter how long i charge. The timer keeps running, and the voltage reaches 13,8 before going to trickle.
I upgraded it's firmavre with 363, making it a kind of G2.
I opened it up, and brushed away some traces of moisture.
I also found a transisitor / voltage regulator of some kind on the secound pcb. It looks like it has overheated once..
Althought the instrument works fine when powered from the charger.
It's hard to read what the possible overheated part is named.
I tried charging the unit with a 12v dc transformer-supply. By then, I can reach 30 min runtime.
If someone should happen to have a opened up satlook, would you look at the part and tell the name?
Or if someone has parts for a meter...
Interessted in how long you charge yours, and runtime and so on..
BTW: I have no working backlight. Is that a feature I should have, or is the firmware common for more models..?!
ModerationUploaded image as attachment - SM
Satlook micro+ /G2  - charging behavior-satlookimg1-jpg
Last edited by STL442; 21-03-2009 at 09:39 PM. Reason: uploaded image as attachment
STL442 is offline   Reply With Quote
Old 24-04-2009   #2
My System: SATELLITE
Can you take a full larger photo, too small to clear see the detail.I really like to see what inside the box. I am still searching its circuit diagram for this metre. thank you
Birdseeker is offline   Reply With Quote
Old 27-04-2009   #3
Here is picture of bottom printboard.
3mb..
I'll get the top pcb tomorrow..
AdminWell when you do please upload to our server as previously requested, I have done this one for you
Satlook micro+ /G2  - charging behavior-dsc04518-jpg
The Following User Says Thank You to STL442 For This Useful Post:
Birdseeker (28-04-2009)
Old 28-04-2009   #4
Thank you very much.
Old 29-04-2009   #5
Gonna need a few more days until I have the picture of the top PCB..
Old 04-05-2009   #6
Here is a picture of the top circuit board on the satlook...
Satlook micro+ /G2  - charging behavior-dsc04549-jpg
Birdseeker (06-05-2009)
Old 06-05-2009   #7
behavior, charging, micro, or g2, satlook
