whats mer plz
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 01-04-2009   #1
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro
whats mer plz
hi if a meter has a MER calculation/value has been added function what does it mean plz thanks iwol
iwol is offline   Reply With Quote
Old 01-04-2009   #2
kenny1234's Avatar
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn.
Modulation Error rate, its the measurement of modulation distortion very long winded to explain dont know if i can lol, basically the more MER the better.
Plz feel to correct me if i'm wrong but i believe 20db Mer is the threshold 24db or more is ideal
Poor Mer quality can give rise to corruption making the signal unstable.
I went on an understanding Digital signals course and the chap who took it was struggling to put it in laymens terms and thats his job so i wont try lol
kenny1234 is online now   Reply With Quote
Old 01-04-2009   #3
Mod and septic resident
Channel Hopper's Avatar
There is a Modulation Error Ratio rather than rate
_http://zone.ni.com/devzone/cda/tut/p/id/3652
The modulation error ratio (MER) is a measure of the signal-to-noise ratio (SNR) in a digitally modulated signal. Like SNR, MER is usually expressed in decibels (dB). MER over number of symbols, N is defined as:
where
is the I component of the j-th symbol received
is the Q component of the j-th symbol received
is the ideal I component of the j-th symbol received and
is the ideal Q component of the j-th symbol received.
whats mer plz-mer-gif
Old 01-04-2009   #4
rolfw's Avatar
Real name: Rolf
Same here, the training course on the meter covered it, but they were hard pushed to explain exactly what it was, apart from being a combined measurement. It is however a nice measure for dish alignment, as if this measurement is good, then the rest tend to fall into place.
Rolf
Old 01-04-2009   #5
satelliteman's Avatar
Real name: Paul
I always look at MER simply as a digital CNR (C/N) measurement and will vary on what is being measured
satelliteman.
An Installers Choice
Follow us on
Old 01-04-2009   #6
thanks guys im even more confused now :-)
Old 01-04-2009   #7
Just wait until you need to know about Eb/No
Old 02-04-2009   #8
im not even asking:-)
Old 01-06-2009   #9
patmos's Avatar
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst
Thank you guys for the definition of MER. I could find its definition on the web.I see that most meter sold will boast that they can measure this unit. I work in a Earth Station and what we checked is the Eb/No,C/N and BER. This term is never used.
patmos is offline   Reply With Quote
Old 1 Week Ago   #10
black22's Avatar
Real name: Karthic
My System: Beetel SD 95, Airtel STB, 6 ft mounted Dish, Quad LNB, & Pll lnb, 1GB USB TV Tuner card, Rover Fast S2 and Rover Examiner HDTV
Thumbs up MER Characteristics.
QAM MER — Modulation Error Ratio
The modulation error is a calculated quantity indicating the mean or the maximum deviation of the I/Q values from ideal signal states and thus provides a measure of signal quality.
The following diagram shows the vectors used for calculating the modulation error:
The modulation error is specified as rms and as peak value. To calculate the modulation error, all decisions fields are investigated on after the other.
To obtain peak modulation error, the maximum magnitude of the difference vector (error vector) formed by the vector of the ideal and the actual signal status is determined for each decision field. From the maximum value of these results, the peak MER (modulation error ratio) is calculated using the following formula:
To obtain the rms modulation error, the squares of the magnitude of all differential vectors formed by the ideal-status and actual-status vectors are added up, and the number of symbols is counted. Then the rms modulation error is calculated as follows:
The peak and rms modulation error can also be specified on a logarithmic scale. Conversion is done using the following formula:
For quantized I/Q values, the peak value is output in discrete form only since no averaging is performed in the calculation. The rms modulation error can be calculated within the limit values specified in the following table. The limit values are obtained for quantized I/Q values:
Orderof QAM , MERRMS min, MERPK min, MERPK min , MERdB min
4 , 0.5 % 1.563 % 98.44 % 46 dB
16 , 0.5 % 1.398 % 43.32 % 46 dB
32 , 0.7 % 1.976 % 29.33 % 43 dB
64 , 0.5 % 1.364 % 20.46 % 46 dB
128 , 0.7 % 1.952 % 13.66 % 43 dB
256 , 0.5 % 1.356 % 9.471 % 46 dB
Attached herewith the Vector diagram and Formulas to calculate the MER.
whats mer plz-vectors-jpg   whats mer plz-mer-formula_1-jpg   whats mer plz-mer-formula_2-jpg   whats mer plz-mer-formula_3-jpg
black22 is offline   Reply With Quote
mer, plz
