satellite meter self made usd 30Section for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Regular Member Join Date: 03-01-2009 Location: india
My System: dvb s2 usb for pc | just telling my idea, please tell me if i am wrong anywhere. instead of buying costly satellite meter I prefer given method for capture satellite signal. 1. buy any portable FTA receiver with facility to enter frequency. 2. buy portable black and white tv 3. buy power extension cable for tv and fta receiver. all cost you around usd $30. ok now when ever you want to capture satellite signal please follow given steps. 1. find which satellite signal you want to capture from lyngsat.com, dishpointer.com or any other same site. get direction and other details. 2. enter that frequency in to your fta receiver. 3. go to terrace, attach your lnb with receiver, give av out to portable bw tv., select your frequency in fta receiver and start moving dish until you get best signal. equipment setup will cost you around usd $30. | ||
| ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ ku dish 65cm , skystar 2 rev 2.3 pci card, dvbviewer pro. location : Gujarat, INDIA. Express AM22 at 53.0°E ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes, that's what many members do. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, I do the same,but I use an 8 inch colour LCD, inconjunction with my meter. Costs more than $30 though here. | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #5 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | I really hate to say this but..... The Technomate series do, and no doubt many others. | ||
| | #6 | ||
| | #7 | |||
Even my ID digital has direct frequency entry and that is at least 6/7 years old never even crossed my mind that someone would make an stb without | |||
| | #8 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | ||
| | #10 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, I have used a Strong FTA box, the one I came accross was a Technomate clone, with seeming identical hardware and User Interface. | ||
| | #11 | |||
| Member Join Date: 23-04-2009 Location: Surrey, UK
My System: Sky+ 60cm Dish Octagon SF818 PVR |
I presume by frequency you mean the transponder values eg. 12525 V 27500 3/4 - but isn't there a danger that you might be catching same/similar frequency from another strong satelitte signal? | |||
| | #12 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, that will happen. But if you are on the wrong satellite you don't get the channels that were scanned in. | ||
| | #13 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | You will only catch a signal from another satellite if the dish isn't aligned right. Most meters try to use a transponder list where the transponder on the sort satellite does not appear on neighbouring satellites... but will cross identify with satellites further along the arc. This is what the TV output is for. For example if I am trying to line up on 1W with my meter (Satcatcher Excel-TV) when I switch to the TV picture I want to see the poker channel. If I don't it must be the wrong satellite. | ||
| | #14 | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | I always used to use an old Fortecstar classic, fantastic receiver for setting up with. Not much use for anything else though | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| | #15 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | some thoughts, ideas, tests and considerations can be found here: _ttp://hangebi.com/?p=27 also check "DVB-S" category from the link, that article is continiued. | ||
| meter, satellite, usd |
