Lucuna Battery ConnectorSection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Specialist Contributor Join Date: 21-08-2004 Location: Wales
My System: Technomate 1500CI+ and Hauppauge WinTV NOVA-HD-S2 on a 104 cm motorized dish and Humax HDCI200 on 90 cm motorized dish. |
I am looking to buy a Lucuna Battery Connector like the one in the photo below. Any suggestions on places to buy, and do I need a crimping tool to put the connector on or can it be soldered? Thanks | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | I normally get them from RS, but you need an account. Maplin appear to sell them, but there's no photo on their web page. The ones I use are crimp on, but you can bend over the tabs with small pliers, and stick some solder on for good measure. Another place that sells ythem is Rapid Electronics- 2.54mm KK PCB Connectors | ||
My System: Technomate 1500CI+ and Hauppauge WinTV NOVA-HD-S2 on a 104 cm motorized dish and Humax HDCI200 on 90 cm motorized dish. | Thanks for the reply, sorry for taking so long to get back to you. | ||
| battery, connector, lucuna |
