Handheld tv for dish setupSection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Member Join Date: 18-07-2009 Location: Derbyshire UK
My System: Raven 43cm minidish. Zinwell quad lnb. |
Has anyone connected a small handheld tv to their satellite setup & got sound and vision? I have a number of dishes to install at unoccupied properties and was thinking of buying a cheap secondhand handheld with an av input socket. Since these are powered by their own internal batteries I believe I can avoid certain licensing issues. I've had a quick look at what scart to composite av adapters are available but nothing seems to quite fit the bill. Thanks, Sid | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Thread moved to correct section. A good second hand meter/analyser would suit. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, I have a 7inch LCD TV, it has composite video and audio AV inputs. Works fine, bought it new from Ebay | ||
| Grimm Member Join Date: 08-03-2009 Location: Blackburn, Lancs
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500 | I have a 7" LCD. I don't bother with sound, and use composite video. I have a 30m long Co-Ax with made up with composite jacks for carrying reciever video signal up to the dish. | ||
| I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off! | |||
| | #5 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | A satlook NIT or even a Micro wouldn't set you back that much. Much more professional. | ||
| | #6 | ||
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500 | | ||
| | #7 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | You can buy a 7' or 10' portable, battery powered LCD tv, with built in DVB-S receiver for about $120 in China. Made by Lilliput company ltd. | ||
| | #9 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The trouble with professional meters is that you have to spend a significant amount more to get at least same functionality that can be achieved with a receiver+Tv. I only use my meter when it's raining. | ||
| | #10 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Well, sometimes meter is necessary, for example when it's required to fine tune LNB skew for lowest polarization, or to detect interference. | ||
| | #11 | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | |||
| dish, handheld, setup |
