Safety equipmentSection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 |
What safety equipment do you use for working at heights, and what do you attach it to? | ||
| Specialist Contributor Join Date: 06-09-2008 Location: Sunny Scunny
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn. | I use similar tackle to this link _http://www.applegroup.uk.com/shop.htm 2 rope system. Basic description Main ladder fastened to the wall via eye bolt and ratchet strap(ladder mate at bottom to foot ladder with non slip mat/leveller), rope is fastened around top rungs and microlite, which then runs down to the base of the ladder where it is attached to keep it tight. Now using rope grab and harness ladder access is now safe. If roof access is required, 2nd rope hooked onto the top of the roof ladder, both ladders then ratcheted together nr guttering. Cows tail(Hook) allows me to hook onto ladders, giving extra point of contact, useful when moving between ladders or transfer of rope grap between 2 ropes. Using harness ladders can be scaled safetly and once you get into swing doesnt slow you down too much. If i need to leave the roof ladder-i use the chimney strop(fastnen around chimney connect my harness too it Hope that helps | ||
| The Following User Says Thank You to kenny1234 For This Useful Post: | foden (11-08-2009) |
| | #3 | |||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Also, what about working on a flat roof where you are surrounded by a 50 foot drop and there is less than a metre between the job and the drop. | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Huevos, Laddermate image attached. Also take a look at the video for a set up procedure of safety equip (file to large to upload) _http://www.county-safety-services.com/_docs/ladder_systems.htm | ||
| | #5 | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| equipment, safety |
