NIT and constellationSection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 |
Who's using a meter with NIT. I haven't got NIT on either of my meters but never have trouble identifying a satellite. How much of a bonus is NIT. Also how useful is a constellation diagram? And how is it read? What do you look for? | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | NIT can be a useful tool for identification... but, only one of my older meters actually had this function ![]() A constellation diagram will display the gain and phase of each bit in the stream of freq your measuring. Errors refer to points seen straying into areas occupied by other points (easily identifiable). Again, never really used it. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | NIT is invaluable if you do installations for more than just the three or four common satellites, or motorised systems. My little Satlook NIT has saved me so much time over the years and I won't contemplate getting rid of it until my present meter gets an NIT software update. Many of the meter manufacturers rely on the slow and unreliable transponder comparison method of satellite identification, it's about time they woke up. Constellation can be useful, but personally I have hardly ever used it nor found a serious need for it. | ||
| | #4 | |||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | How do you mean it has saved you time? Do you mean because it doesn't cross identify? I've got a Satcatcher and that doesn't have NIT, but I can switch to the TV picture to confirm what I'm pointing at. Is NIT quick than this, or is it instant as soon as you align with the satellite it signal that in some way? On your NIT do you ever use the TV picture? Or do you think the new Micro would be fine? Oh, and a couple of other things, how sensitive is the tuner in those meters, and, can new transponders be added via the keypad or is a computer necessary? | |||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | With the best will in the world I can't tell you whether NIT will be as useful to you as it is to me, you'll have to make your own decision on that. Bear in mind that not every satellite has FTA channels to use as a guide (some don't have TV channels at all) and it isn't always easy to cross check with the computer to check channels and frequencies on satellites. No idea about the new Micro I'm afraid, haven't used it and don't know whether you can add transponders, I've certainly never added transponder to my Digital NIT, as with NIT I don't need them, I pick a peak on the spectrum and check it. Wouldn't say that the tuner on the Digital NIT is the most sensitive in the world and it may not be the same tuner as the Micro anyway. | ||
| | #6 | |||
| A very good piece of kit for the money (well mine was until I blew it up). | |||
| There is a very fine line between "hobby" and "mental illness" | ||||
| | #7 | ||
| | #8 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Rolf, On 28E does the meter recognise all 4 satellites individually? And can you choose the polarisation that it is working with? | ||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Can't remember what it reads on the different satellites in the group, it may just say Astra2 or 28.2 East (it will read what the broadcaster puts in the table), will check when I get a chance, but that is something you can determine by the frequencies, as they are listed by satellite on Lyngsat. Polarisation and 22Khz is switchable by pressing two buttons, there is no auto channel plan on the Satlook NIT, and in fact I prefer to switch manually as you can define easily which trace you are looking for. | ||
| | #10 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The NIT Network ID only gives you the basic satellite name and orbital position. For the Astra 28.2 cluster - | ||
| | #11 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | I think we are at cross purposes. I'm so used to using my meters that I'm thinking all work the same. On mine I just pick a preprogrammed transponder from the memory. Am I right in thinking that instead of selecting a transponder from the memory that you choose a frequency, voltage and tone to make the transponder on the fly? If so this sounds much more flexible. | ||
| | #12 | ||
| Not sure I understand your question, with the NIT you have the choice of pre-programmed, or select any part of the satellite output by the live scan. | ||
| | #13 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | On my meters to use the meter I have to choose a preprogrammed transponder from the memory. What I am asking is if this is different with the Satlook micro. I think with that meter you just choose a frequency (using the control knob rather than a keypad), polarisation and hi/lo. I've tried finding out from the manual but it is pigeon so it is hard to tell | ||
| constellation, nit |
