MaxPeak SAM shows V Low qualitySection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Member Join Date: 07-10-2009 Location: Devon, UK
My System: MaxPeak SAM |
I have bought a MaxPeak SAM alignment meter. My home sky box and my neighbours both show a 80-90% level for both signal and quality when using the sky boxes signal test page. The new meter I am testing gives a 70-80db signal strength, but only a very low 5% quality, and even lossing this and dropping the lock. I very much doubt both mine and my neighbours dishes are miss aligned, especially as I have no issues with reception. I use a Zone 2 dish down here in devon. Anyone had any issues with these relatively unknown meters? Thanks in advance. Martin. | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Not familiar with it - can you Post up some Piccies? Is it properly and securely connected? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Have you set it on the correct satellite, Astra 28.2 and not Astra 19.2? _http://www.maxpeak.tv/sam.php | ||
My System: MaxPeak SAM | Yep, defo on 28.2 - it works better on the V than the H polarisation. I have tried it on 3 different installs so far, directly to the coax at the digibox. I have also tried directly to a dish today, and the quality is higher at around 25-30%, but I must admit I was expecting it to match the sky digibox's signal page. What sort of readings would you expect on a pro meter? | ||
| low, maxpeak, quality, sam, shows |
