New firmware for Lacuna Sat Meter
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 22-06-2005   #1
My System: Channel Master 1.2 1224 H2H. Traix TD88. Sky+ Echostar 3600. P4 2k. Broadband 2
Hi all
I want to update my lacuna sat meter with uptodate sat files, but alas the firmware in the meter is to old to accept the new files V. 4.05 meter dated 2002
Does anyone know how to update the firmware or where to find it? The lacuna site doesnt have the relevant files.
Hope someone can help
digiguy is offline   Reply With Quote
Old 13-07-2005   #2
dundeebloke's Avatar
My System: pass
Question Wolsey Sat 2 Meter
Hi, i recently purchased a Wolsey satellite meter, and am have difficulty updating the sat files to it. I have the download lead and sat files and using satloader, and when trying to download datasets to it i get a Send new line (0) failed error come up on screen. Has anyone else had this problem and found a means to do it successfully. Many thanks. P.S. Firmware of meter is 5.1.3 Uk Multi V4.U15
dundeebloke is offline   Reply With Quote
Old 13-07-2005   #3
rolfw's Avatar
Real name: Rolf
No idea I'm afraid, not many members have these, have you tried the help address on the Wolsey site?
Rolf
Old 27-08-2005   #4
remlap's Avatar
My System: Technomate 1500CI+ and Hauppauge WinTV NOVA-HD-S2 on a 104 cm motorized dish and Humax HDCI200 on 90 cm motorized dish.
Thumbs up
found this loader program I have not used it myself as yet.
http://www.ssi-iraq.com/software/satmeter3.zip
run up ok sofTware version 4.0.6 data set UK Multi V4.U17
remlap is offline   Reply With Quote
Old 17-09-2005   #5
remlap's Avatar
wolsey meter support
this is a link to the Wolsey meter support site.
http://www.metersupport.co.uk/data.htm
Old 17-09-2005   #6
remlap's Avatar
coms port
Just a thought have you set up the right coms port?
click below
Old 06-02-2006   #7
My System: Echostar DSB-2200 80cm motorised dish & standard Sky+ setup with Pace receiver
If this info is still required......
This may have happened if the meter was not powered on when you attempted the update , turn on the meter, run the update with Satloader, when complete disconnect from the pc & reboot the meter.
Regards Mac
Mac_UK is offline   Reply With Quote
Old 04-07-2008   #8
zac2613's Avatar
My System: none
TO WHOM THIS MAY CONCERN
Wolsey and Lacuna are the same meters
I had the same problem (Send new line 0) and fixed it myself (not complicated to do) JUST A RESISTOR
If you have the tool to take the back off the meter and know how to use a soldering iron.
Contact me
IF I THINK YOUR UP TO IT ILL EXPLAIN HOW TO DO IT (AT YOUR OWN RISK)
zac2613 is offline   Reply With Quote
Old 04-07-2008   #9
Amo Amas Amant Admin
Topper's Avatar
Ahem
If you want people to contact you fill out your Vcard details. Do not post your Email address on the forum it is against the rules.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 08-11-2008   #10
My System: Viewsat Extreme w/1.6mtr Square
Contact me
Yes, please. Have had the issue with my meter for the last year, and now the Canadian support site seems to have disappeared. Any help would be appreciated. PM me please with your email address. Thanks...
LarryGB is offline   Reply With Quote
Old 10-11-2008   #11
zac2613's Avatar
My System: none
Hi LarryGB
It didn't work in the end. but i did find a way, have you made the lead yourself, can you take the D serial plug apart, if so let me know and i'll explaine Here what i did to get the dataset into the meter.
zac2613
Old 10-11-2008   #12
Hi LarryGB
zac2613
When we purchased our Lacuna, it came with a factory made cable, one end serial, other mini din. Here is a picture of the cable pinout as provided by the manufactuer's website. I'm prepared to rebuild this cable if necessary, or make the mod right on the board's din socket connections if that's possible. [BTW I spent 27 years in radio/tv service so I'm not afraid to work on this unit.]
New firmware for Lacuna Sat Meter-download_pinout-gif
Thanks....
Old 11-11-2008   #13
zac2613's Avatar
My System: none
Hi LarryGB
If you look at your meter's din connector, not the din plug, rotate the meter till it looks like the diagram below, it should look like this.
bbbbbbbbbbbbbbbbbbbbbbbbbbb *--*-----------------Flying lead
bbbbbbbbbbbbbbbbbbbbbbbbbb * ----*
bbbbbbbbbbbbbbbbbbbbbbbbbbb *---*----------------Flying lead
Where I've drawn 2 lines you need to locate those pin connections on the circuit board, and solder 2 flying leads that can come out of the gap to the side of the power connector/or somewhere, they don't need to be long, i used alarm/telephone type cable for this, and put the meter back together.
Get the latest dataset from lacuna, and start the loader program,make sure you've set the com port correctly, turn on meter, strip back a little insulation off the end of the flying leads, and without directly shorting the wires, squeeze them between your finger and thumb, and try to send the data to the meter, if you see the loading bar loading to the meter, don't let go of the wires, or you will break the download, if it still comes up with (Send new line 0) then you will have to keep trying till you get it.
To those of you reading this you may well think I've lost the plot, but in fact i haven't.
By squeezing the wires together, your putting a resistance across the flying leads, and HarryGB, I've found that when my hands are sweaty, worked best for me, but wetting my fingers, then drying them did not have the same effect.
It worked for me , so should work for you, let me know how you got on Mate, it may work first time, but if not keep trying, keep trying, till you get it, once done tape the wires to the side of the meter, and write down what you did, and keep it in a safe place, for the next dreaded time.
zac2613
Ps Ill be monitoring the thread today, so if you got any questions then please ask. And just for you HarryGB if you attach a glass diode to one of the flying leads, you may even pick up a radio signal. LoL
The Following User Says Thank You to zac2613 For This Useful Post:
LarryGB (11-11-2008)
Old 11-11-2008   #14
zac2613's Avatar
My System: none
Sorry Harry, but i tried editing the diagram, but it wont stay were i put it, look at the meter so the power socket is to the right of the data connection, when looking at the meter, also look at the diagram as if its a circle, you should get my drift.
zac2613
Old 11-11-2008   #15
zac2613
Hey, Thanks....
I will try this later today, and I will see if I can get some digital shots to upload here, and do some editing and experimenting. I'll try and trace back the connection functions from the D connector, so we can see what is actually going on. Possibly a capacitor or open resistor is causing this affect. Of course I cringe at SMT's and poor eyesite...
Later....
Larry
Old 11-11-2008   #16
zac2613's Avatar
My System: none
Hi HarryGB
If your meter probes won't fit into the holes, just use a needle.
Ive tried to locate the problem but cant/won't touch the Smt's, with a normal iron, so having to read components in situ, and is not the best way.
If you look at your diagram, the fly leads are connected to pin 1 & 5 of the din plug, which is the same as looking at the meter.
zac2613
Old 11-11-2008   #17
zac2613's Avatar
My System: none
Ha Ha Ha
I can see what you mean about bad eyesite, HarryGB ??????
Sorry LarryGB.....What a Plonker LOL
Old 11-11-2008   #18
Ha Ha Ha
Actually, I was referring to my bad eyesite , but I have to "share that wealth" with you.
So, I've traced the 9Pin D Sub back to the PC board throught the Mini-Din Male and Female. The pin's in question according to the RS232 functions are Pin 1 [upper in your diagram] on Mini-Din is the RX lead, Pin 5 [lower in your diagram] is the Xmit lead. Of course the function on the meter will be reverse of that, i.e. RX to TX and TX to RX.
It may have something to do with the bias voltage on those pins, and how your skin resistance is pulling up or down the terminal voltages there.
I'm going to take a few voltage readings, and then play around with the scope and see if I can see anything unusual. Time to get out the resistance substitution box and experiment. Taking pictures as we go, so will post them when I have time....
Old 11-11-2008   #19
Well,
I've tried various ways of simulating the load/coupling/injection etc of the programming input, and still no downloading of dataset. I've scoped the serial data from the PC through the immediate input circuit on the meter, including two Toshiba P181GB SMT SOP4 photo-couplers, right up to the main PIC 16F877 micro-processor chip, and everything seems normal. There does not seem to be any output from the PIC, ie as a response to the serial port request, and possibly there is a PIC chip fault, or support circuitry. [Although other functions of the chip seem normal, power-on, data selection, LCD drive, RF/channel/Freq selections].
I've looked at the RST line, and seems to be functioning, so we may not have a low part-count-repair, short of system replacement.
Already wasted too much time on this, unless we have someone else's insight on this, this one's going back on the shelf.
Guys???
Thanks for help anyway, Zac....
Old 12-11-2008   #20
zac2613's Avatar
My System: none
Hi LarryGB
I hoped that it would work for you.
Ill say one thing recently i tried downloading an altered dataset in to the meter, and it would not go, it didn't mater what, so i left it, then one day i tried it again and it worked, more than once ?????? the only thing i could think of that was different than before, was that my fingers were slightly sweaty due to the central heating being on,
The only thing i can think of, is i equaled the Resistance needed to switch a transistor in some way shape or form.
But sadly not in this case. but do try again one day you never know...
This is not a wind up, if someone does have this problem do try the above and if it work's for you, please post a reply so others may follow
Ps, LarryGB i know you'll be the first to post if anything comes to light.
Good Luck
zac2613
Old 19-11-2008   #21
My System: dishnetwork
Lost mine....
hey guys gonna jump in on this one, i have a sat meter and it never had problems loading updates,went to update it a few days ago and my cable is gone. Is it possible to cut the end of a straight through rs232 cable and solder on a 6 din to the pinout that was posted, cause i tried it and this home made jobby is not working. thanks in advance if you have any info to offer.
Wickedcid
wickedcid is offline   Reply With Quote
Old 20-11-2008   #22
zac2613's Avatar
My System: none
Hi Wickedcid
If you followed the diagram instructions, you should have no problems, however as you don't upload to the meter often, did you make sure you set the com port correctly.
zac2613
Any questions you have, anything you don't understand,
anything you need explaining in layman's terms.
This forum can help you...
Yes its frustrating, getting used to a new Piece of Equipment and can be brain taxing, especially if you're new to it aswell...But as long as you can type/read & reply, Thats all you need to do.
And if someone answered your prayer's, please let the forum know.
Someone else may have the same problem.
Don't just leave without a thanks.
wickedcid (23-11-2008)
Old 21-11-2008   #23
Hi Wickedcid
zac2613
Yes sir my com is set ok and i did use a multimeter to make sure pin from rs232 was same on 6 din,i only use 4 wires from the rs232 to the 6 din correct. Thanks in advance as i would love to get this fixed....
Cheers wickedcid
Old 23-11-2008   #24
Hi Wickedcid
zac2613
Hey bro i went back and checked to see if i went wrong somewhere as you feel pretty sure that diagram is right,now you were 100% on the money as i messed up . I was looking at everything and tracing from front view's not back,meter loaded first time and i cannot Thank You enough as i could not find this info anywhere.
Cheers Wickedcid
Old 03-12-2008   #25
zac2613's Avatar
My System: none
Glad you sorted it.
However if you were working on the voltage side of a device, you could of damaged it.
Simple rule Check, Check & re-Check..
zac2613
firmware, lacuna, meter, sat
Similar Threads
multiswitches spiney Tutorials & How To guides 10 24-02-2007 05:43 PM
Lacuna Sat Meter Yellow sky digital meter Rd100 Satellite Meters and Installation Equipment 2 18-04-2006 12:31 PM
DigiPro Sat meter aliasa65 Digital systems 5 01-09-2005 08:05 PM
sat meter lexden DISH SETUP: Single sat, Multi-Sat & Motorised systems 1 28-01-2004 01:11 AM
