satlook micro
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 25-02-2006   #1
My System: tm1500
Question satlook micro
hi ppl,
i recently got a satlook micro and dont find the instructions that came with it very useful.please does anyone know the A-Z on how to use it to locate satellites? i understand it should be pretty quick.[IMG]http://www.*****.co.uk/forum/images/smilies/beak.gif[/IMG]
i'd be very greatful to hear from you.
thanks
deyno is offline   Reply With Quote
Old 25-02-2006   #2
satmaniac ,DIY man
maniacop32's Avatar
here you go
read this and
maniacop32 is offline   Reply With Quote
Old 25-02-2006   #3
satmaniac ,DIY man
maniacop32's Avatar
here you go
read also this
File Type: pdf SATLOOK%20Micro%20+%20Eng%20ver.%202.0.pdf (494.5 KB, 39 views)
Old 25-02-2006   #4
My System: tm1500
satlook meter
thanks,but it still doesnt explain it all.what should i do starting from scratch.basically i put the dish together then where do i go?? (i hope you dont think this is a dumb question )
Old 25-02-2006   #5
rolfw's Avatar
Real name: Rolf
You've bought a tool which requires some prior technical knowledge, you probably would have been better off getting the Digisat Pro, a basic but useful meter.
First thing you do is set up the meter in the menu and tell it that it is connecting to a universal LNB.
Then you connect it to the LNB and move the dish around until you see the signal bar increase as you get near a satellite, the meter has transponder presets for some satellites.
When you have found a strong signal, go into the Digital display, this will show you the signal to noise ratio and bit error rate, they are a percentage display, so tweak for as high a reading as possible. This display should also tell you which satellite you are receiving.
Test the signals on both horizontal and vertical.
Rolf
Old 25-02-2006   #6
rolfw's Avatar
Real name: Rolf
Sorry, forgot the Micro doesn't have a spectrum display, uses strength bar guages instead. Have altered above post.
Rolf
Old 26-02-2006   #7
My System: tm1500
Cool satlook micro
hi rolf,
i finally got a hold of things and got it to work somehow....its not that straight forward but your post helped me imensely.it has loads of other features that i'll slowly get to grips with i guess.
anyway cheers mate for all the help.i'd be lost otherwise.
Old 26-02-2006   #8
My System: tm1500
@ maniacop32 :just wanted to say thanks for all your help.this gadget isnt the most straight forward to use in that it doesnt take you step by step but your post was very helpful.
cheers
Old 26-02-2006   #9
rolfw's Avatar
Real name: Rolf
Glad you're getting some success.
I've had the Satlook Digital NIT for some time now and find it a very useful tool, it outperforms meters which cost four times the price. As you say, the Micro will do an awful lot and I'm sure that you'll have fun experimenting with the additional features.
Rolf
Old 09-05-2006   #10
My System: SATELLITE
Red face
Hi Rolf
I just bought the SATLOOK Micro Plus sat metre, however the preset list does not has the satellite that I am interested. How do I save the transponder into the meter? Are there any website that I can download the satellite's transponder such as ASIASAT 3S into the SATLOOK Metre?
Birdseeker
Birdseeker is offline   Reply With Quote
Old 09-05-2006   #11
rolfw's Avatar
Real name: Rolf
You can either add them directly to the meter, or use the editing/upload software from the Emitor.se site.
You don't need all of the transponders, only a couple of reference ones.
Rolf
Old 09-05-2006   #12
My System: tm1500
satlook transponders
Hi guys
The presets for the transponders on the satlook micro can be added/edited by :
-turn the meter on
-go to digital and enter (black button)
-scroll down to freq and enter (black button)
and now the frequency should be editable using the big round button at the top.
-once you get the freq you want then just exit then memory and save.
ps (i found that i had to enter the name of the satellite as well or it saves it without a satellite name)
i hope this helps.
cheers
Old 10-05-2006   #13
Thank you very much
Thank you RolfW and Deyno, I will try later. Do you known where I can aquire further information other than the manual came with the instrument on how to use the SATLOOK MICRO + ?
Best regards
Birdseeker
Old 10-05-2006   #14
My System: tm1500
Cool
hi birdseeker,
you must be in luck coz in your neck of the woods; AUSTRALIA i came across a website which sells satellite eqpment and sell the satlook micro.they have put together an instruction dvd on how to use the meter.
the link to the shop is
http://www.satplus.com.au/category20_1.htm
best wishes and let us know how you got on.i wouldnt mind having a copy
Old 10-05-2006   #15
Originally Posted by deyno
hi birdseeker,
Thank you Deyno
I actually waiting for my DVD by post...thank you.
Best regards
Birdseeker
Old 11-05-2006   #16
Do you guy this problem on SATLOOK MICRO?
Hi ...
Do you guy had this problem when doing the text edit on the Satlook Micro, it has very slow respond when doing the backward such as from b to a or 8 to 1 etc. However, no problem with the forward direction.
I also found that when using the big knot doing the scrolling for upward direction also experience slow respond but now problem with downward.
Last night when I tried the text edition and sabving the trasponders for few satellites, my intrument was out of power. I charged about 3-4 hours when I got it (new), uisng and play around no more than one hour. May be I did not charge it long enough, so I do the charging last night till this morning for about 9 hours. Am I over Charging it? Is that 10 hour reading when doing the recharge for battery was the max limit that I can be charge?
Thank you...
birdseeker
Old 11-05-2006   #17
My System: tm1500
hi,
the problem you've mentioned about the knot button being slow in one direction is something that i've also experienced on mine.think its in all of them.
as for the battery life; i was advised to charge it fully (at first charge) for something like 8hrs (sorry cant quite be exact,it was a while back) .
then after this for no more than 3 hours and this should avoid over-charging and killing the battery.
i think to clarify this; best bet would be to contact the manufacturers and confirm.
cheers
Old 11-05-2006   #18
hi,
cheers
Thank you Deyno
I will do that in future charge no more than 3 hours. When I read the manual it, I think it stated that 3 hours for 85%full, so I did that. After a few tried saving the transonders, it ran out the power. Therefore, I watch carefully on the LCD screen while charging...it stated something like 30min of 10 hours....2hour or 10 hours, so I assumed that I it will take 10 hour to fully charge the battery.
Anyway, I must say that you had gave me a lot of helps. Otherwise I have to wait for my DVD to help me figure out on how to save the Transponders. I also wish to thanks Rolfw for his advise too, now I am much better understood how to used the metre.
I wish that I could had some sort of software that can work with SATLOOK Micro text edition, it is a pain of input the name and freq. I was wonder why Emitors didn't recongnised that problem? I hated that after I saved the name or freq. then i realised that I made a tiny mistake, I have to redo the transponder and its name again, Deyno, do you have a better way of doing the correction such as typing error like Telcom instead of Telkom.
Thank you...
Best regards
Birdseeker
Old 11-05-2006   #19
My System: je suis la
thanks mstr
etoile1219 is offline   Reply With Quote
Old 05-07-2006   #20
Hi Rolf
I am not sure how to make use of the 13/18v function, can you tell me how?
I am also have query about the transponders input to the metre, if the transponders was vertical, should I use 13 volt and 18 volt for Horizontal signal? Or it doesn't matter which voltage was choosen?
Thank you......
Best Regards
Birdseeker
Old 05-07-2006   #21
rolfw's Avatar
Real name: Rolf
Hi, the 13v and 18v settings apply to vertical and horizontal respectively.
Rolf
Old 06-07-2006   #22
I have to reset my transponders in the metre again...thank you Rolfw
Best regards
Birdseeker
Old 11-07-2006   #23
digdog's Avatar
Hi Chaps
I am now the proud (if somewhat bemused at the mo...) owner of a Satlook Micro+ and much appreciate the info in this thread. However after some hours rummaging I can find no reference on the OZ website to the CD mentioned in deynos earlier post.
Is there a catalogue number for this CD please and if anyone comes across a copy can I please have one - I will make good any out of pocket exes - thanks!
Birdseeker
Just charged my Micro+ for first time - took the full 10 hours but window display showed it dropped down to trickle charge (from rapid) for the last few hours - and when it got to the 10 hours charging stopped automatically. I dont think I will try and recharge again until it goes pretty flat.
Had a rummage on Emitor site - cant find anything that is obviously editing software - got the Firmware uploader and Micromem.exe - havent tried connecting Micro+ to pc yet so I could well find the editor when I do, perhaps? Any ideas please - thanks!
I married Miss Right. I just didn’t realise her first name was always.
digdog is offline   Reply With Quote
Old 14-07-2006   #24
Originally Posted by digdog
Hi Chaps
Birdseeker
Hi Digdog
I am having the same problem too, I think it is normal. The CD you mention although it mentioned on the OZ web before, but I am still waiting for the disc....2 months now......
Old 14-07-2006   #25
digdog's Avatar
Wow - that is a wait!
Wonder if it is still available - I had a fairly good rummage around the site and all I came up with was the Satlook Micro+ was out of stock! No mention of cd.
Up to now I havent found any other sites/sources that might help us I'm afraid...
micro, satlook
Similar Threads
Flash memory erase neotionbox3000 GIVARGIS Receiver software, international Section 20 12-09-2006 04:25 PM
octal tv micro dvb da kaka rop64050 Octal 2 27-03-2006 10:16 PM
satlook micro babu0611 DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 24-02-2006 07:05 PM
vx micro can this still be used rjbrom Cards & Programmers General 4 22-09-2004 11:45 PM
