RO.VE.R Rover Satellite meter software
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 15-05-2008   #26
My System: Topfield 7710 HD PVR, Humax HDCI2000 HD Triax 1.1m (on 0.8w), Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2
Hi Satwino
Thanks for the PM. Glad you can now program meter with transponders yourself. In the SDM2 programming the High Low column refers to the frequency band see _http://www.digitalsat.co.uk/astra2freqplan.html for instance. Each sat may use different definitions of High or Low so best to check.
Thought it best to reply on the forum so all can benefit if they have the same query.
Regards
Jem
Last edited by mhku; 15-05-2008 at 11:40 AM. Reason: no live links - check the rules
developers is offline   Reply With Quote
Old 15-05-2008   #27
Sorry mhku I know the rules just forgot to use my head when reading my typing - thanks for the edit
Old 20-05-2008   #28
My System: VSAT INSTALLER
Question RJ connector pinout
Originally Posted by developers View Post
By the way I also have a few of the chips available (just the 16 pin micro interface chip) as specified on the wiring diagram so if anyone wants a chip and wiring diagram with pin outs to build their own they are just £2.00 each.
Hi thank you for your post and to all other here in the forum.
I here in Kenya and wonder if you could just post the pinout of the small RJ connector, the rest i can do it here, it is simply a RS 232 to TTL converter.
You could also use the cable used for the Nokia 3310 duly modified, but surely at a cost more expensive than 2 Pounds.
Kind regards
Enrico Li.
Sat uplink broadcaster engineer.
5z4es is offline   Reply With Quote
Old 20-05-2008   #29
I'm not commenting on your suggestion as I don't know! but the pin out I used was
Meter
01 TX
02 RX
03 Reset (8ms to ground) unused
04 +5v
05 Boot for firware upgrade (=5v to ground) also unused
06 ground
Old 04-06-2008   #30
My System: echostar 2110 2ci/echostar 808 via 2ci/matrix reloaded/opos 105/titanium/vr3/fortec HD/Quali HD/diablo/DB500S/110cm motorised
Hi guys,i have 1 of these meters sdm2,mainly use it for 19/28 and 13 hotbird,was wandering if any1 knows what the others are like 352 355 and 330 in the meter,any help please hoping it has 1 west somewhere but can not see it,current software vers is 1.05,thanks
jasmine1 is offline   Reply With Quote
Old 04-06-2008   #31
Hi Jasmine1
352 = 8 deg west, 355 = 5 deg west and 330 = 30 deg west. I thought standard set of transponders included 359 or 1 deg west but if not you'll need a lead and software as above or send the meter for an update. 1.05 is not the latest firmware (transponder lists can be addded at any time and do not show on start up) for the meter it's 1.10 on mine when on the start up screen which might need updating to see newer sats (I don't know!).
I'm just putting the final touches to my new transponder list, updating changed frequencies and adding missing sats which will use about 75 of the available as well as making a new matching crib list with the instructions as came with the meter to give all the usual sats between 45 deg w and 45 deg e.
Jem
The Following User Says Thank You to developers For This Useful Post:
jasmine1 (04-06-2008)
Old 04-06-2008   #32
Hello developers,just wierd as to why 359 1 west is not in
Old 04-06-2008   #33
Do you have 50 entries at the moment? my old list did and that had 359. I've attached the list that came with the meter, some entries are out of date but it may help you start your own if you don't want to send it away. 1 deg west is popular for the footie I understand but I've not tried it.
Jem
File Type: zip Channel Satellite Instrument Files .zip (705 Bytes, 55 views)
Old 04-06-2008   #34
Jem
Hi jem,thanks for the list but havent got any software to open it with,plus no manual for the meter so dont know what iam doing to be honest.
Old 04-06-2008   #35
Jasmine1
I've Private Messaged you if you check your inbox on the forum.
Jem
Old 22-08-2008   #36
My System: New to this and I am just starting so when i'm set up i'll change this
Hello if anyone still has the wiring diagram fro the sdm2 update lead then id love to have a copy of it so I can make my own cheers .
wh1tey is offline   Reply With Quote
Old 23-08-2008   #37
bro
My System: DM500S MOTORIZED
could you pm me with the contact info please as a friend needs one of these leads
thanks
bro is offline   Reply With Quote
Old 15-09-2008   #38
Sorry for the delay I've been away but I do still have a few of the chips available but I can't private message you yet as I think you need at least 5 posts.
Old 18-09-2008   #39
My System: satellite & aerial
instructions
hi has anybody got an instruction book,or know where i can get one for sdm2 meter
thanks
andy
andyntl707 is offline   Reply With Quote
Old 18-09-2008   #40
I have something called a user's guide, 12 sided a5 booklet which I could photocopy and send but I don't know where you'd get a download.
Let me know via my website (see contact info in the profile for my username) if you need it.
Jem
Old 19-09-2008   #41
hi
thanks i got 1 downloaded via email from matin turner direct who are the main uk importers.
now all i need is to get it reprogrammed it works ok on astra 2 but not on the others so might send it to them to be serviced & updated
regards
andy
Old 20-09-2008   #42
Hi Andyntl707
That's great, can you attach the manual to a post so we can all see it please?
If you want to make an upgrade lead or want one ready made let me know as I have a list for another batch!
Jem
Old 20-09-2008   #43
hi jem
i think the guide i got from them is the same as yours but i can forward this to the site if i knew how to & yes please i would like a lead when you have them
regards
andy
The Following User Says Thank You to andyntl707 For This Useful Post:
developers (20-09-2008)
Old 23-09-2008   #44
Andyntl707 I sent your lead, software and manuals on cd , my channel list and index card for the case lid last night. Let me know if you have any trouble but if you follow the pdf guide I think you should be OK.
Jem
Old 23-09-2008   #45
hi jem
thanks have sent you an email
regards
andy
Old 29-09-2008   #46
meter lead
(developers )
cheers for the reply and sorry its took me so long to get back to you lol (we are like ships in the night pmsl)
Managed to make myself a lead and its works a treat. thanks again though mate
Old 17-11-2008   #47
My System: Technomate TM9100 DarkMotor & 1.1m Dish Diablo 2.3 Sly Digital
Hi guys,
Been looking for a Serial lead for the SDM2 for a while now, and google brought me here!
Are you (Developers) still supplying leads or diagrams & chips ?
If so would be eternally grateful.
Many thanks
Archie (Mis-spelled nickname !)
ArcjieX is offline   Reply With Quote
Old 17-11-2008   #48
Yes I can still help. As you haven't been a member for long I can't private message you but if you click on my developers name, it should have a drop down box, click on "visit developers homepage!" and there is a link to send me an email.
Jem
Old 17-11-2008   #49
Thanks Jem.
email is on its way.
Archie
Old 17-11-2008   #50
Thanks Jem, email on its way.
Archie
meter, rover, satellite, software
Similar Threads
How can I upgrade my Reciver Auto Search keys Receiver software, international Section 3 02-11-2005 04:23 PM
Digital satellite viewers lose free channels net1 Sky Digital (BSkyB) and Astra 28.2 East General 5 16-06-2005 01:22 PM
Can't use satellite dish as in listed building paul wyatt Sky Digital (BSkyB) and Astra 28.2 East General 13 14-03-2004 08:10 PM
Will the BBC's satellite dream ever take off? net1 Daily Satellite and Broadcast industry News 0 26-06-2003 08:49 PM
