Unaohm & diSEqc switching?
Section for the discussion of Satellite Meters, sat-beepers and Installation equipment
Old 26-04-2006   #1
Is anyone using Unaohm 314 spectrum analyser?
I am wanting to know how to change diseqc switching when setting up a monoblock lnb,when ligned up on Hotbird so i can peak the Astra signal.
thanks
malsat is offline   Reply With Quote
Old 26-04-2006   #2
rolfw's Avatar
Real name: Rolf
Unfortunately my EP313 doesn't have DiseqC switching, but you might perhaps PM iceman, as he uses a 314, I'm sure he won't mind.
Rolf
Old 26-04-2006   #3
thanks rolf
I see you have a Annie,whats it like?
can you pre store digital channels from any sat and then use them to peak the signal on a later install?
thanks
Old 26-04-2006   #4
iceman's Avatar
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD
@malsat
Unfortunately i have never used the DISEqC functions on the Unaohm EP314 so i will not be able to offer any advice...
I have the manual for the meter if that is any help to you...could send you the relevant section if you wish..
iceman
iceman is offline   Reply With Quote
Old 26-04-2006   #5
rolfw's Avatar
Real name: Rolf
Originally Posted by malsat
thanks rolf
thanks
Yes, I use the Annie mostly for terrestrial though, as I find the Satlook NIT better for satellite work, you can as you say save both channels and traces for comparison.
Rolf
Old 26-04-2006   #6
Thanks guys,
yes can you send me the relevant section please Iceman.
thanks again
Old 26-04-2006   #7
iceman's Avatar
DISEqC Module on EP314
The DISEqC module adds to the EP314 peripheral drive in conformity with the DISEqC 1.1 standard.The trasmission of repeated commands is not allowed.
How to enable/disable DISEqC 22kHz note
1.Press the key DSQ/22k
2.Use the multifunction keys UP or DOWN to position the cursor in correspondence with the 22kHz reading.
3.Press SSQ/22k to alternatively enable/disable the tone.The presence of the signal is indicated on the OSD dsiplay.
4.Once the function has been performed,the EP314 returns to normal operating mode.
Transmission of a DISEqC command
1.Press the key DSQ/22k.
2.Use the multifunction keys UP or DOWN to position the cursor in correspondence with the DISEqC reading;this is followed by the name of the last cmmand transmitted.
3.Press DSQ/22k to transmit the same command.
4.Once the function has been performed the EP314 returns to normal operating mode.
At the previous point 3,to transmit a command different from the one proposed,proceed as as follows:
1.Press the multifunction key SELECT
2.Select the command to be transmitted by means of the multifunction keys UP and DOWN.
3.Press DSQ/22k or BACK to return to menu,which will have been up-dated to include the new command.
4.Press DSQ/22k to transmit it.
Hope this helps
diseqc, switching, unaohm
