Satellite FindersSection for the discussion of Satellite Meters, sat-beepers and Installation equipment | |
| Regular Member Join Date: 29-11-2006 Location: Cheshire
My System: 1.2m CM, 36v Positioner, DB7020Si. Diablo, CAS3+ |
Are the satlook mark 3's any good as a sat finder? I'm keeping my eye out for a used satlook to replace the digisat pro that i have. Does a spectrum analyser make much of a difference, or is it just a nice feature? Thanks PJ | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card. | Satlook mark 3, very nice! It will blow your digisat pro out of the water. Spectrum analyser will make all the difference ![]() I also use the satlook micro+ very happy with it. Or you could go for the satlook NIT, another good meter. | ||
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | hi crossbones sorry to be dumb but what advantage does the spectrum analyser have when peaking your dish | ||
| | #5 | ||
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card. | As a general rule, the satellite meters are all you need to help find a specific satellite. A spectrum analyzer then permits you to view individual carriers on a said satellite. | ||
| | #6 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | interesting i've been looking to buy a meter for the last couple of months the spectrum analyser bit does it really need to have one for only a small motorised dish ? | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | There are several advantages with using a meter with spectrum display, not the least that you can identify different satellites at a glance, compare cross polarisation readings for Skew adjustment and see an instant signal improvement reading. If you advance to the Satlook Micro or NIT, then you get the added advantage of BER readings and Signal to noise ratio readings, great for peaking the dish. | ||
| | #8 | ||
| bog standard Join Date: 02-07-2007 Location: norwich
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2. | sorry for hijacking your post but what spectrum aniliser would you consider to be the best for sat and ter .been looking at a televes one at 1500 pouds .comes with c/n card and opional ber card.any decent stuff out there under a grand. | ||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I can't remember seeing anything for both sat and terrestrial digital for under £1000, at least not brand new. There are now several superb spectrum analysers on the market for around £1,600 plus vat, I have the Swires Annie 204, but actually prefer the Satlook NIT for satellite work, the Annie is superb on Terrestrial Digital. | ||
| | #10 | |||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | hoping going from a digisat pro to satlook micro and don't want to get confused with the meter | |||
| | #11 | ||
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card. | Think it stands for Bit Error Rate, its good that its 0, if you get figures then the channel is normally too weak to lock on to. | ||
| | #12 | ||
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2. | thanks 4 the reply on the aniliser.it would be a good to have a reviews section on meters as they are so exspensive .and u cannot rely on the manufactures bumf as they all say theres is best.i for one would review my wolsey sat and terr just about do the job after 2 years of tinkering meters. | ||
| | #13 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I'll look at doing that moosegoose, although ideally reviews should be done after comparing with other meters and not many members will have had experience of more than one. But at least these would be from our members' personal experience and valuable from that point of view. | ||
| | #14 | ||
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2. | ok may be we could have a list of the most common meters and we could mark them 1 to10 on batt life, durability ,back up and after sale ,ect ect. | ||
| finders, satellite |
