skystar 2 fine tuning motorised dish with softwareDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 04-10-2007 Location: eastmidlands
My System: am2 4.4 1gig mem skystar 2 |
problem sorted sorry for that hi some time ago i had a program that sat inside sat vewing program that fine tunned the dish ie moved it left and right till it got the strongest signal then put the right settings into the program so it knew where to point the dish the next time u wanted to go to that sat possition thank u in advance my setup is skystar 2 with dream tv running am2 dual core 2.6 1 gig ram | ||
| Regular Member Join Date: 28-05-2007 Location: Terre Rouge, Mauritius
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst | If this is possible then it would be a great soft. So it will do some sort of step tracking as in bigger earth station. The antenna control unit would move UP/DOWN and East/West in different combinations, then it will memorise the position with highest signal level and will return to that position to optimize tracking. Actually in E station an Antenna control unit which does that. Not a software running on Windows. | ||
| dish, fine, motorised, skystar, software, tuning |
