Technisat SkyStar USB - No SignalDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| | #26 | ||
| Member Join Date: 20-06-2006 Location: Dubai, AE
My System: Dual Core 2 2 GHz 1 GB Ram nVidia 7300 Go SkyStar USB Asiasat 3s Nile Sat Pas Sat NSS 6 | hi HB13DISH, i returned my faulty ss box back to the shop once again and told him that i need an alternate product, which he would arrange in teh next few days... can you suggest some good reliable product... i am using a laptop so will need a usb box and must have hdtv support ! Thanks | ||
| | #27 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
I am using Hauppauge Nexus-S which is PCI and it is very good. But since you need USB for the laptop, then look for their other models: _http://www.hauppauge.co.uk The USB model is not HD The CI model type will enable you to insert smart cards. Please bear in mind that I am not recommending any of the USB products, since I haven't used them myself, but the manufacturer is one of the best in the world. | |||
| signal, skystar, technisat, usb |
