TSReader Lite ProblemDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
Installed TSReader Lite on PC running Windows XP Pro. During the installation I had a choice of selecting drivers for my DVB-S card. But since Hauppauge Nexus-S was not on the list, I chose Hauppauge Nova. The application when launched showed an error message: Failed to Initialize hardware. Uninstalled, rebboted, installed again, but this time I didn't get a choice of drivers and only the same error message keeps popping up. Any idea where my initial choice is stored on the PC and how to get back the installation chioce of drivers. I cleaned up the subfolder in the Programs folder, but no luck. Which driver should I have chosen during the installation? Will try to install to another subfolder. Thanks. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I'm fairly certain the Nexus-S uses the same chipset as the Technisat Skystar 2, which won't work with TSReader. Llew | ||
| I think that Technisat was on the list, but I could be wrong. Which card are you using which works with TRReader? Also, do you know of other similar applications that I can try, if Nexus-S is not compatible? Thanks. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | | ||
| The Following User Says Thank You to Llew For This Useful Post: | HB13DISH (15-04-2008) |
| lite, problem, tsreader |
