prog dvb & skystar 2Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 23-04-2008 Location: Spain
My System: Skystar 2 Prog DVB 80cm Dish | Hi i am quite new to this! I have installed a skystar 2 card into my pc and installed prog dvb and followed big teds idiots guide to installing it.Thanks ![]() I have not yet got my dish up,doing it at the end of the week,i have read i should point it at Hotbird as this has the most channels? But as well i have come a cropper lol, i installed _ftp://download.technisat.com/de/soft/550.zip i dont know why lols but now it has deactivated/my card cannot be started or something it says,can i backtrack and get rid of this somehow? sorry for being an idiot! ![]() | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Remove the aforementioned file and re-install the SS2 driver and application from the CD that you presumably had with the card. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | andyman2008 (23-04-2008) |
Thanks, that sorted it out ![]() So for me the best option is to point my dish at hotbird right? Do you think it would be easy to install the dish alone? | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Plenty of advice here if you're going to install the dish yourself andyman. If you're just going for the one satellite with a fixed dish you need at least to know that you have a good line of sight to the satellite and know where the satellite is in regards your location. Llew | ||
| | #5 | ||
thx for the advice ![]() i thought i'd make sure i had a good job done so i have just phoned a local satellite chappy to come saturday and put my dish up, the only thing concerning me was that because i am going for a fixed dish would hotbird be my best choice? with regards to my skysat2 pci card+prog dvb or dvb viewer with regards to my soft cams etc? | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | ProgDVB and vplug emulator will be fine. Regarding choice of satellite, mignt be worth investing in a monoblock LNB and setting your dish up for Hotbird and Astra 19E. | ||
| The Following User Says Thank You to Llew For This Useful Post: | andyman2008 (24-04-2008) |
| | #7 | ||
Hi, and thx,i have my tv in the other room with a dish set up for sky, i think this is the astra 19.2 one.....do i just put vplug in the prog dvb folder like i did with yankse and sm2? and do you know if there is a good selection of films,sport etc on hotbird? thanks again. | ||
| | #8 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Your Sky dish is on Astra 2 (28E). Astra 19E is probably the best for films and sport (Pr*mier bouquet) at present. T P S on Hotbird OK too, but liable to change encryption soon and disappear fron emus. Extract vplug files into the progDVB plugin folder, its softcam needs to be updated frequently. Llew | ||
| | #10 | ||
| Specialist Contributor Join Date: 05-04-2005 Location: Midlands UK
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP | Like LLew said....get a monoblock; then you can switch between Hotbird and Astra 1 | ||
| The Following User Says Thank You to pgh13 For This Useful Post: | andyman2008 (24-04-2008) |
| | #11 | ||
Hi i have just been talking to the chap who is installing my dish on saturday and i asked him about the monoblock for astra 1 and hotbird, and hes told me it wont work unless i have diseqc 1.2 or something? I am using my computer, prog dvb and sky star 2 PCI card as my receiver, could you please tell me if it has this diseqc 1.2 and if this will be possible for me? thanks again for all your guys help (I just read that i should be using DiSEqC 1.0 for switches. DiSEqC 1.2 is for motors.) does this help at all? The Technisat site says the sky star 2 features diseqc 1.0 so maybe i am ok? | ||
| | #12 | ||
| Member Join Date: 26-03-2008 Location: NE Scotland
My System: skystar2. | Id think your ok with 1 or 1.2... I use an ex EuropeOnline Skystar 2 (v2.3) card with progdvb and a motorized dish, most of the time pointed to 1°W but if it can shift a motor it can work a switch. | ||
| | #13 | |||
| | #15 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Apparently Digi TV should be OK. Haven't tried myself (prefer C*nal Sat on the same sat - using a Diablo cam in a proper STB) | ||
| The Following User Says Thank You to Llew For This Useful Post: | andyman2008 (25-04-2008) |
| | #16 | ||
ok great,could i email you Llew as i dont think i am supposed to ask my next question in this forum as to what and where i should drop in the root folder of prog dvb? or i can give you my email in this forum? mine is EMAIL=Deleted | ||
| | #18 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Just copy the vplug zip file into the progDVB plugin folder and extract all the files there. | ||
| | #20 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Good to hear it's working OK. Enjoy | ||
| The Following User Says Thank You to Llew For This Useful Post: | andyman2008 (26-04-2008) |
| | #21 | ||
H i Llew progdvb was crashng and just not showing anything/or signal sometimes so i installed an earlier version off their homepage no thats doing the same? all i get is a black screen now damn... | ||
| | #22 | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| Try another application like DVB Dream. I read that they are more stable. | ||
| The Following User Says Thank You to HB13DISH For This Useful Post: | andyman2008 (26-04-2008) |
| | #24 | ||
I dont know why but now i am getting a problem with the software which came with the card,there is a program called setup4pc running in my tray which used to be green saying signal ok,but now it is red saying no signal? i know the signal is there because i have had it running all morning,i have reinstalled everything again and when my computer boots up the icon is green saying signal ok but when i scan for channels it goes red and says scanning no signal,in the ptogram it says transponder status out of lock? please help this has turned into a nightmare?edit:i just selected alice sat: 19.2 E degrees in the set up list from setup4pc and the icon is green again now saying signal ok but whenn i start prog dvb or dvb dream it drops the signal | ||
| dvb, prog, skystar |
